Crawlspace Insulation And Encapsulation: What If There's No Sill Plate? - Insulation - DIY Chatroom Home Improvement Forum
Old 01-28-2015, 08:36 PM   #1
Restoration professional
Rewards Points: 302
Crawlspace insulation and encapsulation: what if there's no sill plate?
I'm insulating and encapsulating a crawlspace built of concrete blocks. There is no sill plate. Yes, it needs a sill plate, but I will not be putting one in. Best practice is to insulate the walls and the space between the joists with XPS board before attaching the vapor barrier, but at the moment, because there's no sill plate I can put my hand into the centers of the blocks. So it will basically be a chimney to bring in vapors and moisture if I don't cap them off. What is the right way to do this?
halliwellc is offline   Reply With Quote
Old 01-29-2015, 12:22 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 926
Spray foam them up to seal them is probably easiest.
Crawlspace Encapsulation and HVAC amg1950 HVAC 0 10-22-2013 08:11 PM
