Crawlspace Insuation - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree2Likes
Old 06-20-2016, 04:42 PM   #16
Rewards Points: 96
Re: crawlspace insuation
Well, from their web site: http://www.rmax.com/files/2114/5401/...x_TSX-8500.pdf
They are showing it installed without an additional thermal barrier and they are claiming an excellent fire protection performance.
I like it, but only your local code authority can say for sure.
Bud
Bud9051 is online now   Reply With Quote
Old 06-20-2016, 05:10 PM   #17
Rewards Points: 86
Ok so as a final confirmation to everything:
1. Insulate the rim joists with Roxul or foam board(unfaced or foil faced?).
2. Only need foam board on the 2 outside walls, the foam board(thermax or rmax, will check with local authority) going up all the way up to 3 inch from the top of the wall, so that there is a termite inspection area.
3. Use a 10-20 mil Poly run up 12 in above ground.
4. Seal the vents with foam board.
5. Use some plywood to cover half of that opening between basement and crawlspace.
6. No holes needed in the ducts.
Thanks again!!
nemo77 is offline   Reply With Quote
Old 06-20-2016, 05:27 PM   #18
Rewards Points: 96
1. Insulate the rim joists with Roxul or foam board(unfaced or foil faced?). Either
6. No holes needed in the ducts. For now
Bud
The Following User Says Thank You to Bud9051 For This Useful Post:
nemo77 (06-20-2016)
Old 06-20-2016, 05:49 PM   #19
Rewards Points: 86
Bud
Hey Bud, what do u mean for now? When would this change? Thanks!
Old 06-20-2016, 06:55 PM   #20
Rewards Points: 96
Hopefully there will be enough natural air circulation, but if not or it stays too cool, then you might want to introduce some conditioned air.
Bud
nemo77 (06-20-2016)
Old 06-24-2016, 11:24 PM   #21
Registered User
Rewards Points: 526
If you read that link I gave, you get a slight energy penalty leaving the floor batts in place when insulating the walls. Pull the Fg and add to attic. Using rock wool on the rims without drywall for an air barrier could be risky. IMHO.
Running the AC (even in your mild climate) will bring in summertime moisture with the warm outside air through the rim framing cracks, and condense warm moist interior air on the cold rims in winter-- seal them with caulking first, then use foil-faced foam board; #10, here; http://www.diychatroom.com/f103/insu...-roxul-307313/
Gary
The Following 2 Users Say Thank You to Gary in WA For This Useful Post:
nemo77 (07-09-2016), ProGreen (07-06-2016)
Radon soil gas, water w/radon, & other household air quality mitigation plans ylekyote HVAC 9 02-08-2016 03:46 PM
Crawlspace treatment for older home? Pittsville Building & Construction 3 06-02-2014 09:28 PM
Crawlspace Encapsulation and HVAC amg1950 HVAC 0 10-22-2013 08:11 PM
Dirt floor conditioned crawlspace with horizontal 80% furnace, and mold remediation WillK General DIY Discussions 0 04-29-2012 10:20 PM
crawlspace exposed to outside and damp djbauda Building & Construction 5 07-30-2007 07:49 AM
