Cover ( "bury") Insulated Ductwork With Blown In Fiberglass ? - Insulation - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Windows on Wash
Old 07-03-2016, 06:03 AM   #1
Rewards Points: 129
Cover ( "bury") insulated ductwork with blown in fiberglass ?
My 1970s house has the 2nd floor HVAC system in the attic. The metal ducts are wrapped with foiled backed fiberglass insulation (old and compressed) which is probably not doing much. Unfortunately, access to many of ducts virtually impossible to re-seal and re-insulate ( would require drwall demo and big mess in the house) or even repalce with R-8 flex. However, the ductwork is accessible enough to cover with thick layer of blown-in fiberglass insulation. This would be quick and inexpensive solution (yes a compromise) if it worked. Will it help signifantly and are there any other issues to consider ? -Thanks
rkpatt is offline   Reply With Quote
Old 07-03-2016, 11:40 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 856
Re: Cover ( "bury") insulated ductwork with blown in fiberglass ?
You can cover it. You would be well served to seal everything you see as a gap in the foil facing. If you have enough space, wrapping it in insulation and combination of air barrier is not a terrible idea either.
Bud9051 likes this.
Old 07-03-2016, 03:14 PM   #3
Rewards Points: 136
As an alternative to blown fiberglass, check for blown cellulose. It is much denser and adds some resistance to air leakage, ducts as well as the entire ceiling. In addition to sealing the ducts you can, look for the big leaks, around chimneys plumbing vents, or drop ceilings. And don't forget the attic access, air sealed and insulated.
Best,
Bud
Bud9051 is offline   Reply With Quote
Old 07-03-2016, 04:04 PM   #4
Rewards Points: 129
There is currently about 10 inches of blown in fiberglass of the original batts.
Best,
Bud
Old 07-03-2016, 04:34 PM   #5
Rewards Points: 136
Sounds like you are close to the minimum recommended level but adding more is not bad and if you are going to cover the ducts, then a few more inches across the entire attic floor isn't that difficult.
Do you plan on blowing it in yourself?
Do you have access to cellulose?
Check the 09 minimum levels for where you live here: https://energycode.pnl.gov/EnergyCodeReqs/ Remember, these are minimum levels. Also, these are for 09. 2012 and 2015 code levels have been adopted in some locations so check your code office.
Bud
Help!! trying to cover up fiberglass insulation Anthony45 Insulation 5 07-24-2015 07:05 PM
Dryer insulated vent cover Ranger1227 Insulation 24 11-10-2013 11:52 PM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 02:33 PM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 02:53 AM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 07:34 PM
