Consequences Of Sealing Rim Joists In Basement? - Insulation - DIY Chatroom Home Improvement Forum
Old 02-13-2014, 08:59 PM   #1
Rewards Points: 121
Question
Consequences of sealing rim joists in basement?
Hi all,
I'm in the process of finishing my basement. I'm debating about how to insulate the rim joist area in particular right now. My Primary concerns are indoor air quality and moisture issues. I'm personally putting temperature control at the bottom of the list. As it stands now, there are visible air gaps in a couple of places near the sill plate. You can of course feel cold drafts in the winter and we have quite a few bugs in the basement. Rounding out relevant background information...the house is located in St. Louis MO and was built in 2008. The basement slab is roughly 40x40 in size.
My concern with sealing that area is the effect on the indoor air quality. Any advice on the consequences of sealing things too tight? Or should I not be concerned about that occurring?
mklein49 is offline   Reply With Quote
Old 02-13-2014, 09:12 PM   #2
Rewards Points: 1,002
Don't worry.
cleveman is offline   Reply With Quote
The Following 2 Users Say Thank You to cleveman For This Useful Post:
joecaption (02-13-2014), Windows on Wash (02-14-2014)
Old 02-14-2014, 04:08 PM   #3
Registered User
Rewards Points: 526
2008 house, you may have an ERV/HRV in your house.... http://www.greenbuildingadvisor.com/...ngs/hrv-or-erv
Caulk first, above/below the rim joist, under the sill plate. Then add FF FB with canned foam- last paragraph; http://www.buildingfoundation.umn.ed...oistphenom.htm
I doubt you would leave a small window cracked open, year-around- same as the rim joist expanding/contracting with the seasonal changes; http://www.buildingscience.com/docum...d-but-strange/
Gary
Old 02-14-2014, 07:25 PM   #4
I just insulated the rim joist in the basement of a house built in about '56 and it was totally bare.
Funny story. I had a guy going out of business and he wanted me to go and clean out his warehouse and haul everything away. So I scored one sheet of 1 1/2" xps, two sheets of 1/2" foil faced, and a bunch of 1/4" fan fold, along with some unfaced R38 bats and some kraft paper R19, along with a bunch of other crap.
After looking at it in my garage for a year or so, I decided to insulate the rim joist in that house. I knew they were 2x10 joists, so I ripped everything down to 9 1/4.
What was useful were those piles of 1/4" fanfold insulation. I found that in hard to reach areas, those 1/4" pieces slip in much easier than a 1 1/2" piece. So I would put 6 1/4" pieces in a bay, or 3 1/2" pieces or 1 1 1/2" piece. Then I had some left over, so I went back and got rid of all my material.
This was about a 1200 sf house. Then I went through 3 cans of foam spraying around the perimeter of each bay and on the ends.
Next I cut the 24" wide r38 and r19 into 12" wide strips and put them in each bay, wrapping them in plastic to keep the fiberglass from moving around too much. This took some time. I had to buy one additional roll of r19 and I got the encapsulated stuff.
Now the entire rim joist is insulated with r48 to r29 and the whole thing cost me about $28 and 3 short days of work.
I've heard more than once that this is the biggest bang for your buck regarding insulation and I believe it.
So if you guys ever find yourself with a lot of fanfold insulation left over, just set the blade high on your table saw and rip it all up.
Old 02-15-2014, 07:34 AM   #5
Rewards Points: 121
Question
So it seems like the sealed xps approach is great for handling condensation along with providing a base for temperature control. I do not believe I have an HRV/ERV, so i still wonder about tightening up the building too much. Is my concern invalid?
Old 02-15-2014, 07:53 AM   #6
Think of rim joists as little wall cavities. You wouldn't think of leaving a full 8' wall uninsulated in your basement (at least you shouldn't). Well, rim joists may only be from 8"-12" or so tall, but they're still important. Older homes rarely had them insulated because of lack of education at the time as well as costs of materials. But uninsulated rim joists (or "bond" as some call it) can and will lead to cold floors above, especially near those exterior wall areas. Air quality should be least of your worries, but to each his own. Think of the water pipes coming up in those areas, they need a barrier between them and the outside air temp, not to mention ductowork if you have any in those areas. The absolute best os to have them spray foamed at 1-2". You can even buy the do-it-yourself foam tanks (looks like a gas grill propane tank, with a hose and wand) and do it yourself....although it's messy. This would be the best both for insulation and air quality. Or resort to the good ol' fashioned UNfaced fiberglass insulation, unless it will be covered such as drywalling that ceiling, then you can use faced in most areas....but that leads to possible fiberglass dust.
Huskee is offline   Reply With Quote
Old 02-15-2014, 07:54 AM   #7
No such thing as tightening up the building too much, unless you were to spray foam your entire house, walls and ceilings as one fluid coating throughout, then you'd need air handlers. In your case, no worries.
Old 02-15-2014, 08:09 AM   #8
Rewards Points: 121
Question
Ok, that eases my concerns. Thanks for all the replies so far!
So for installation,I have the engineered joists. Would I need to notch each corner of the xps for a good fit. Or can I just fill that cavity with foam? What's the recommended installation method there? Also, what is the best method for cutting the xps?
Old 02-15-2014, 08:31 AM   #9
Rewards Points: 808
Spray foam the snot out of it. I did my entire 1st floor (it was a finished floor, 1 bed, 1 bath a walkin closet and a den) on slab when I gutted it, rim joist & walls. I also did the windows and doors with the best money could buy. Now the heat hardly ever comes on down there, it's like a thermos. And the upstairs floors near the exterior walls are as warm as in the middle of the room.
IslandGuy is offline   Reply With Quote
Insulate basement header with imbedded joists??? lackofunds General DIY Discussions 21 04-17-2011 03:41 PM
Bubba's been here. Repairing sagging rim/floor joists. MattFels Building & Construction 7 02-09-2011 05:28 PM
Insulation in basement floor joists and integrated garage speedster1 Building & Construction 3 12-07-2010 05:44 PM
Strengthening Joists Before Basement Finish braverichard Building & Construction 16 06-20-2010 07:28 PM
Sealing basement floor/wall gap countryboy43 Building & Construction 7 06-12-2010 10:00 PM
