Cold Walls, Humidity Issues, Frost Issues With Exterior Doors - Insulation - Page 4 - DIY Chatroom Home Improvement Forum
Old 12-14-2014, 04:36 AM   #46
An old Tradesmen
Rewards Points: 54
Did you have this problem with your old furnace. if not, any chance your old furnace was either an 80% efficient furnace, or if it was a 90%plus, did it get its combustion air from inside the house.
Next time you open the door, and there is ice on the storm door. Scrape as much of the ice off as possible, and weigh it. Is it just a few grams of ice, or is it a pound or more. Just a few grams. Your door is sealed okay. A pound, your door leaks a lot of air, whether you see daylight or not.
You need an HRV.
At 20.9C and 57% RH. The moisuture will condense on any surface at a temp of 12.1C.
Old 12-14-2014, 09:56 AM   #47
Rewards Points: 6
Originally Posted by Howitzer View Post
Not yet... why do you ask? Have a similar issue I presume...
No just curious.
jigger is offline   Reply With Quote
Frost on crawlspace walls Red Squirrel Building & Construction 4 01-10-2011 02:13 AM
Freezing Cold Walls benchmarkman Building & Construction 11 01-11-2010 03:05 PM
Cold Walls apetrag General DIY Discussions 1 03-15-2009 07:49 AM
Frost at top of basement concrete walls dtabor Building & Construction 3 01-16-2009 08:00 PM
Revisiting my cold house issues... pcampbell HVAC 7 10-10-2008 10:55 PM
