Cold Draft At Baseboards And Wood Plank Floors - Insulation - DIY Chatroom Home Improvement Forum
Old 02-14-2016, 05:53 PM   #1
Rewards Points: 2
Cold draft at baseboards and wood plank floors
I've noticed a cold draft coming along my baseboards of one wall but also through the 1/4 inch gap in probably the last 3-4 inches of my wide plank wood floors. The house sits on a fieldstone foundation. I've felt some cold drafty areas in the basement field stone. Is it worth sealing behind the baseboard? where the drywall meets the floor there's a small gap with air flow.
Donedeal is offline   Reply With Quote
Old 02-14-2016, 06:52 PM   #2
Rewards Points: 86
That can help, but the real problem starts somewhere on the outside. Older homes often used boards for sheathing that offer little protection from air flow. Do you know what is inside the walls for insulation? Dense packed cellulose does a good job of reducing unwanted air leakage.
Do you have a basement or crawlspace where you can access the perimeter of the structure where it sits on that foundation. Pictures or a description could help.
Bud
Bud9051 is offline   Reply With Quote
The Following User Says Thank You to Bud9051 For This Useful Post:
Windows on Wash (02-14-2016)
Old 02-14-2016, 10:06 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 766
While every bit will help, the analogy of bubble gum in a dam leak probably holds true here. A more specific and exhaustive air sealing scope is probably called for.
Trims, Floors, Baseboards and Bondo... dolbo Painting 11 02-25-2012 05:02 AM
Mixing wood tones, floor and baseboards papageek Flooring 1 03-28-2010 08:01 PM
Remove dried paint from wood baseboards dunavantc Painting 2 07-16-2009 02:54 PM
DAP caulking question n0c7 Painting 16 10-31-2008 11:31 PM
