Cold Air Around A Dishwasher - Insulate? - Insulation - DIY Chatroom Home Improvement Forum
Old 08-06-2014, 11:03 AM   #1
DJN
Cold Air Around a Dishwasher - Insulate?
This is probably going to sound like a strange question, but here goes. Would putting insulation under and next to a built-in dishwasher help stop passage of cold air that is coming through the wall behind the dishwasher and adjoining kitchen cabinets?
Last winter, a lot of cold air was entering the kitchen under and around the dishwasher, to the point of us literally feeling a draft. Obviously the wall behind the dishwasher and the adjoining cabinets isn't as airtight as it should be. Short of taking the exterior siding off the outside of the wall and fixing the air infiltration and insulation problems, I was wondering if it would do any good to put insulation under the dishwasher where the draft was blowing? Is that even safe since the dishwasher gets hot?
Any advice would be appreciated.
DJN is offline   Reply With Quote
Old 08-06-2014, 11:16 AM   #2
Rewards Points: 248
The cold air will still be entering the house so the best it could do is diffuse the draft so it would be felt elsewhere. A piece of cardboard box the appropriate size would accomplish the same thing.
Old 08-06-2014, 11:24 AM   #3
Rewards Points: 1,858
Need to figure out exactly where the airs getting in.
Pull it out and look at the wall behind and floor below it.
Someplace there's most likely an open hole where the drain or incoming water lines where run.
If there was a problem with the wall not sealed or lack of insulation the whole wall would be cold not just that one spot.
Old 08-06-2014, 12:26 PM   #4
Rewards Points: 133
Insulation insulates. Air barriers block air. If cold air is entering your house from the exterior, you need to seal the hole first. Only then you can apply insulation after that. Some substances (e.g. spray foam) do both at the same time.
iLikeDirt is offline   Reply With Quote
The Following User Says Thank You to iLikeDirt For This Useful Post:
Windows on Wash (08-09-2014)
Old 08-09-2014, 09:08 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 848
Gotta seal up the envelope first and foremost like IlikeDirt says.
Old 08-10-2014, 08:26 AM   #6
Rewards Points: 110
it may not be leaking outside air. it could be inside air, that is not well heated (because its behind the cabinets and DW), that is circulating into the room. just sayin.
Fix'n it is offline   Reply With Quote
Old 08-10-2014, 08:42 AM   #7
Rewards Points: 848
+1
That being said, most dishwashers are installed with poor insulation and wall sealing.
Old 08-10-2014, 04:43 PM   #8
24+ years of fixin'
gmaint's Avatar
Rewards Points: 340
Pull the d/w, foam the open holes, and never ever put insulation under the machine. You may develop a leak sometime and a hidden mold magnet is not what you want in the kitchen.
Gregg M.
gmaint is offline   Reply With Quote
Trickle of Cold Water Pioneer Bathtub Faucet egawrons Plumbing 0 10-25-2012 11:24 AM
downstairs cold want to insulate behind vinyl siding colts49 Insulation 8 09-27-2012 12:42 AM
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 12:59 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Best way to insulate basement in cold Canadian climate dtran Building & Construction 1 07-08-2009 07:48 PM
