Chimney Letting Heater Warmth Escape - Insulation - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By chandler48
Old 06-19-2017, 09:02 PM   #1
Rewards Points: 36
Chimney letting heater warmth escape
There is a fireplace in my home. I plan on never using it. I plan on keeping the home for five years. Is there a quick and easy way to close up the chimney so the heat does not escape?
Intosnow is offline   Reply With Quote
Old 06-20-2017, 04:38 AM   #2
Rewards Points: 254
Re: Chimney letting heater warmth escape
If it is a wood burning fireplace there should be a damper you can close to take care of most of the air flow. They also make chimney pillows, never used one, but they can be inflated inside the chimney to block it.
The risk is someone will come along and try to start a fire and not know the chimney is blocked. There have been instances of a house guest that's not familiar with that issue flooding the house with smoke.
Bud
Bud9051 is online now   Reply With Quote
Old 06-20-2017, 04:54 AM   #3
Naildriver
chandler48's Avatar
Rewards Points: 398
Adding to Bud's comments, if you do use anything but the damper to close up the opening, be sure to attach a string to it with a weight or something that will lay in the bed of the fireplace. That way if someone decides to use it, the string will be readily noticeable and alert them to the obstruction. The string will be innocuous otherwise.
Bud9051 likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 06-20-2017, 05:37 AM   #4
retired painter
Rewards Points: 242
I've seen a few insert a piece of plywood [cut tight] into the opening to close it off [mostly older homes without a damper] Most just paint the plywood a dark color to blend in with the fireplace but I suppose you could also decorate it with some art work.
mark sr is online now   Reply With Quote
New-ish electric hot water heater blowing fuses. roasted Electrical 33 01-11-2017 01:24 PM
chimney cap mortared in place? timingchain Concrete, Stone & Masonry 16 01-25-2014 04:09 PM
Installing an electric water heater in series with boiler paul01420 Plumbing 10 04-20-2013 08:48 PM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 11:23 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
