Chimney Balloon - Insulation - DIY Chatroom Home Improvement Forum
Old 06-04-2015, 09:39 PM   #1
Rewards Points: 4
Chimney balloon
Had an insulation guy out and he quoted $400 to measure, obtain and install a chimney balloon. I see that I can purchase a balloon on line for about $60. Is $340 for measuring and installation reasonable? I measured myself, but I'm worried that this is more of an art than a science, because if the ballon does not fit snuggly, seems like it would be almost worthless.
Herzogma is offline   Reply With Quote
Old 06-04-2015, 11:03 PM   #2
Rewards Points: 6,652
Easier to just construct a Plywood Panel that fits into the opening, and uses wood blocks to secure it in place, by using bolts that use embedded nuts in the wood. Balloons are okay, but do not really keep the noise out.
You could of course just have the Spark cap changed out to one that you pull closed with a chain, that secures inside where the draft door is.
Old 06-05-2015, 06:04 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 928
I think you are fine to install one of these yourself.
Sounds like you have done all the heavy lifting.
How to install chimney liner Rockford How To Guides 3 07-16-2012 04:15 PM
Why a Chimney Liner? Rockford HVAC 0 07-12-2012 10:03 AM
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 10:00 AM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 03:12 PM
