Cellar Ceiling Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 01-28-2017, 11:38 AM   #1
Rewards Points: 6
Cellar ceiling insulation
Hi all
I am looking to insulate the cellar ceiling to make the room above warmer. I have decided to use Celotex.
Following a lot of googling opinion seems to be split as to whether the insulation should be touching the floor boards above, or whether there should be an air gap to allow circulation. Celotex, in their manual, seem to suggest that it should be touching. I am worried though that the floor boards will rot.
I am just wondering what others think? Maybe it doesn't matter?!
Robin1986 is offline   Reply With Quote
Old 01-28-2017, 12:12 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 848
Re: Cellar ceiling insulation
Is the cellar conditioned?
If so, the insulation improvements should be at the wall and not on the ceiling.
Old 01-28-2017, 12:18 PM   #3
Rewards Points: 6
No it's not conditioned
Old 01-28-2017, 12:21 PM   #4
Rewards Points: 848
Is there mechanical or plumbing in that area? Where is the home again?
https://buildingscience.com/document...in-crawlspaces
Old 01-28-2017, 12:30 PM   #5
Rewards Points: 6
In the U.K. Yes there is plumbing and electrics attached to the underside of the ceiling
Old 01-28-2017, 12:54 PM   #6
Rewards Points: 848
I would caution against additional insulation them.
The concern here, if your area gets cold and below freezing, would be that by further insulating the ceiling, you will lessen the amount of energy transfer between the spaces and the cellar could get that much colder and possibly below freezing.
That can present an entirely new set of problems with plumbing down there.
Old 01-28-2017, 01:06 PM   #7
Registered User
Rewards Points: 526
------------------------Welcome to the forums!---------------------------------
A picture would help... Celotex has many different boards with different perm ratings, which board where you looking at? Describe the floor make-up.
Leave a gap for warm toes; https://buildingscience.com/document...al-performance
Gary
Want to raise my ceiling and have insulation questions rjm102478 Roofing/Siding 7 02-01-2013 03:14 PM
Garage ceiling joist, bracing, and insulation ACR_SCOUT Building & Construction 11 01-21-2013 06:05 PM
Holding Insulation on ceiling without drywall? EricCJacobson Insulation 10 08-28-2011 08:36 PM
Existing Cathedral Ceiling Insulation Question Bob Deb Building & Construction 8 12-07-2010 07:54 PM
Vaulted Ceiling Insulation Problem casey_wa Roofing/Siding 13 05-08-2006 09:55 AM
