Which Caulk To Use To Seal Rim Joist? - Insulation - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By jackallis
Old 07-23-2019, 10:47 PM   #1
Rewards Points: 142
which caulk to use to seal rim joist?
this might be a trivial question, but i am confused.
dynaflex230
alexplus
GE silicone
which one?
jackallis is offline   Reply With Quote
Old 07-24-2019, 04:50 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 336
Re: which caulk to use to seal rim joist?
If you are insulating the rim joist area, which you should be doing, you would usually use minimally expanding foam around the perimeter, the apply your insulation. I recommend Roxul for a good tight fit. Waterproof, vermin proof, mold proof and fire proof.
If all you are doing is caulking, I would use an elastomeric caulk which stretches and contracts with the building.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 07-24-2019, 07:25 AM   #3
Rewards Points: 1,954
I think alexplus? which I think is the cheapest. Caulk these days all stay somewhat flexible but even if cures hard, you're still air sealing. Even left over grout will work. After applying, push the caulk in and flat with a flat stick or scraper.
Is this from outside or inside? If from inside, floor joist bays also? If yes, 1" foam board cut 1/4" less than the bay dimensions and fill the gaps with canned foam. Works well even without further insulation and easiest to do. Applying just enough foam is like holding a cracked egg without totally cracking it.
carpdad is offline   Reply With Quote
Old 07-27-2019, 10:13 PM   #4
Rewards Points: 142
plan is to do both.
caulk first and then foam board and spray foam.
chandler48 likes this.
Old 07-28-2019, 07:42 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
Whatever is cheapest and decent. Don't overspend here.
Old 08-02-2019, 05:43 PM   #6
Rewards Points: 304
I just used the cheapest caulk and then insulated over it with rigid foam board.
Kemper100 is offline   Reply With Quote
