Cathedral Ceiling Redo - Insulation - Page 6 - DIY Chatroom Home Improvement Forum
Like Tree6Likes
Old 10-19-2018, 03:41 PM   #76
Rewards Points: 318
Re: Cathedral Ceiling Redo
Originally Posted by Nealtw View Post
You don't want any moist air from the house getting in there. If it were here it would get a 6 mill poly before the drywall,
I know Bud's idea was to 1) use rigid foam to prevent room moisture from hitting the cold roof deck 2) have the air channel vent any moisture that did get through
Not sure about where the blocked moisture would naturally go. But I could see 6mm plastic trapping moisture behind the sheetrock, no?
arcticranger is offline   Reply With Quote
Old 10-19-2018, 04:20 PM   #77
Rewards Points: 92
If the channel doesn't have a lower inlet to work with the high vents then the ventilation basically isn't going to work.
I'm out of ideas.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is online now   Reply With Quote
Old 10-19-2018, 04:27 PM   #78
retired framer
Rewards Points: 298
There should be no moisture in there so it is a matter of keeping it out and there is a different theory for different areas and climates. mostly what you worry about is a leak that would allow house air to get to the vented air above. If that happens warm air would cool on the way and any moisture would condense somewhere, usually beside the rafters where the thermal bridge is and air might find a path. that's not to say air travels thru drywall but it is the holes mostly like wires thru the tops of the walls and light and fan fixtures.
Old 10-19-2018, 05:14 PM   #79
Rewards Points: 318
I'm out of ideas.
Bud
Yea the assembly will stay as it is with sheetrock for air seal, no plastic or Tyvek. I can do some cool decorative things like faux-beams on the sheetrock.
Anyway you can't quit you're my architect
Nealtw likes this.
Old 10-19-2018, 07:08 PM   #80
Rewards Points: 92
LOL, I didn't say I quit, I said I was out of ideas, or at least conventional ideas.
If you leave a gap but have no lower intake there will still be a small amount of natural circulation, cold air wandering down into those dead end cavities and displacing the slightly warmer air and push to join the air above and reach those higher vents. In addition, any moisture that passes to the ait results in lighter air, just like we think about warm air being lighter. So between a small amount of heat and a small amount of moisture the air will circulate a bit.
A tip for all who bury their attics in lots of insulation, plan on a way to get back uo there without destroying the new insulation. In one large attic I created a raised walk down the center and it sure was handy. In many attics I have been in the kind framers left some 2x6's flat across the tops of the joists. Not perfect but better than trying to find each joist to step on.
Bud
Tags
cathedral ceiling , hot roof , polyiso insulation
Ventilated Cathedral Ceiling "Open or Closed Cell" ? brulin Insulation 10 07-20-2012 11:08 PM
Ventilated Cathedral Ceiling "Open or Closed Cell" ? brulin Insulation 2 07-16-2012 11:40 PM
Existing Cathedral Ceiling Insulation Question Bob Deb Building & Construction 8 12-07-2010 07:54 PM
New ridge beam support needed for cathedral ceiling? zachalyse Building & Construction 12 06-06-2010 07:06 PM
ventilation baffles in cathedral ceiling HHac8014 Building & Construction 10 05-03-2010 10:32 AM
