Cathedral Ceiling Redo - Insulation - Page 5 - DIY Chatroom Home Improvement Forum
Like Tree6Likes
Old 09-16-2018, 12:30 PM   #61
retired framer
Rewards Points: 890
Re: Cathedral Ceiling Redo
Originally Posted by arcticranger View Post
Quick update, I have started this project finally. Bud, I completely overlooked this statement by you:
"With spacers to hold the first layer of rigid away from the roof deck that becomes your baffle"
OK got it (bonk) the 2" foam IS the baffle. Should that XPS channel run all the way to the ridge vent?
Yes.............
Old 09-16-2018, 12:50 PM   #62
Rewards Points: 276
The baffle is there to keep the insulation away from the the roof deck so if insulation goes all the way to the ridge so should the baffle.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is online now   Reply With Quote
Old 09-18-2018, 04:34 PM   #63
Rewards Points: 318
So I've got my 2" XPS foam with 2" air channel enclosing 3/4" holes, foamed tight. I should probably have gone with caulk but I lost that detail.
I was surprised it was only 13' from floor to peak.
Now I've got to figure out the best filler for the remaining 6.5 inches. 3 more layers of rigid will run $300 as the first layer took 3 full sheets of 4x8 XPS at $100. Filling it with R23 Roxul will be about $150, I could go R30 Roxul but I'd have to add an inch to the rafters. So with the 2" foam being R10 my options are:
air gap
4 layers of 2" XPS
R40 at $400
air gap
1 layer of 2" XPS
5.5" of Roxul R23
R33 at $250
air gap
1 layer of 2" XPS
7.5" of Roxul R30
R40 at $280
I do have a good deal of 1", 1.5" and 2" XPS as well as a LOT of 1 and 2" foil faced polyiso sitting around but I am not sure if puzzling it all together is a good idea. Also I've been avoiding the foil faced rigid as I don't want to create a vapor barrier.
I can also add a layer of 1" XPS over the inside joists, that would only be $60 or so.
And there will be a ceiling fan up there.
Further thoughts?
arcticranger is offline   Reply With Quote
Old 09-19-2018, 01:36 PM   #64
Rewards Points: 318
Bud
and ps to Bud thank for the great advice, and to the others who chipped in. I do think this was the best solution to my tricky cathedral ceiling issue.
(I can already see the real estate agent's eyes rolling as I wax poetic about my fancy air channel)
Nealtw likes this.
Old 09-24-2018, 02:21 PM   #65
Rewards Points: 318
A few questions if anyone is still out there.
What's the purpose of air sealing the rigid foam that created my air channel? Is it about maintaining a certain pressure? My worker did it pretty well but not perfect. I may tape the seams tomorrow.
I used 2" of XPS for my baffle. Some guy on the greenbuilding site said 2" has a perm rating of .5 and will block drying of room moisture via the air channel. He said I should have used 1" rigid and a 1" channel. I didn't pursue that as those greenbuilder guys seem to go OCD on everything. But I would appreciate any feedback on it.
Old 09-24-2018, 03:12 PM   #66
Rewards Points: 276
Doesn't make sense for that advice to come from GBA, maybe another site using the greenbuilding name. Send me a PM with the link to those comments so I can see who said that.
2" is the desired channel and 1" is considered absolute minimum. As for 2" rigid not having a high enough permeance to dry to the outside, it's not supposed to. The objective is to prevent moisture from reaching the cold roof deck and if any gets through the ventilation is supposed to carry it away. 2" is also thick enough that it's inside surface will remain above the dew point. 1" becomes questionable.
The benefit of air sealing those channels is to prevent air leakage from the house carrying humidity up where it can find a cold surface.
Bud
Old 10-18-2018, 01:25 PM   #67
Rewards Points: 318
My semi-vented cathedral ceiling has been done for a month, the layers from top to bottom are
roof sheathing
2" air channel with 3/4 holes as Bud recommended
2" solid foam (XPS)
6" Roxul
I've been holding off on closing it up to get some wiring done up there like a ceiling fan. Today that was completed.
I'd like to ask for a last bit of advice on closing this ceiling up. Should I go with sheetrock or is metal or some other material ok? The most important thing of course is maximizing the insulation I have done. I'm considering galvanized steel corrugated roof panels as an interior ceiling, mostly because they are light and go with the industrial look of the space. And maybe they can help reflect heat?
Old 10-18-2018, 02:57 PM   #68
Rewards Points: 276
I've never worked with or read about using galvanized steel corrugated roof panels on an interior ceiling. The only concern that comes to mind would be a perfect air seal. Metal expands and contracts with temperature and screws will often end up in elongated holes. The screws with rubber washers might work but unknown how long.
Bud
Old 10-18-2018, 03:19 PM   #69
retired framer
Rewards Points: 890
Drywall and wall paper for the look.
https://www.wayfair.ca/decor-pillows...RoCwPkQAvD_BwE
Old 10-19-2018, 11:07 AM   #70
Rewards Points: 318
Bud
Yes all true. Ever heard of using Tyvek on an interior wall? I'd have to cover it but it is
a) an air barrier
b) not a vapor barrier.
If that was tight it might allow for more creative finish options than drywall. Just thinking.
Old 10-19-2018, 01:49 PM   #71
retired framer
Rewards Points: 890
http://www.dupont.co.uk/products-and...for-walls.html
Highly permeable to water vapour – can be fixed directly to insulation (Sd-value: 0.01m)
That would not be what you want for a ceiling you want to keep dry.
Old 10-19-2018, 02:06 PM   #72
Rewards Points: 276
Tyvek was specifically designed to not be a vapor barrier and it was not intended to serve as an air barrier. It provides a drain plane to shed water while allowing drying to the outside. As for the air barrier, it can help, but an air barrier also needs to be rigid. Tyvek alone would billow in and out with air pressure pumping air in and out as it does.
Bud
Old 10-19-2018, 02:53 PM   #73
Rewards Points: 318
The sheet metal ceiling is just an idea at this point. I found another guy on GBA who actually did it. Interestingly it was on a cathedral ceiling with the same vented + rigid foam + air channel gap setup that Bud gave me. The 3rd entry by Don J describes it
https://www.greenbuildingadvisor.com...ing-wall-panel
My idea was to staple the Tyvek to the rafters, flush against the Roxul, with the metal sheeting directly over it. The Tyvek would be my air barrier and my 2" XPS would be my moisture barrier.
But aside from the difficulty of finding anyone who can do this well, I doubt I could get this assembly as tight as sheetrock. It's kind of amazing in 2018 that there isn't another technology lighter and easier to install than drywall.
Old 10-19-2018, 03:07 PM   #74
Rewards Points: 318
Highly permeable to water vapour can be fixed directly to insulation (Sd-value: 0.01m)
If I add sheetrock this would be my assembly. I assume some moisture would exit through via the XPS to the air channel and the rest I don't know, back out via the sheetrock?
roof sheathing
2" solid foam (XPS)
6" Roxul
sheetrock
Those wallpapers really are cool.
Old 10-19-2018, 03:17 PM   #75
retired framer
Rewards Points: 890
roof sheathing
2" solid foam (XPS)
6" Roxul
sheetrock
You don't want any moist air from the house getting in there. If it were here it would get a 6 mill poly before the drywall,
Tags
cathedral ceiling , hot roof , polyiso insulation
Ventilated Cathedral Ceiling "Open or Closed Cell" ? brulin Insulation 10 07-20-2012 11:08 PM
Ventilated Cathedral Ceiling "Open or Closed Cell" ? brulin Insulation 2 07-16-2012 11:40 PM
Existing Cathedral Ceiling Insulation Question Bob Deb Building & Construction 8 12-07-2010 07:54 PM
New ridge beam support needed for cathedral ceiling? zachalyse Building & Construction 12 06-06-2010 07:06 PM
ventilation baffles in cathedral ceiling HHac8014 Building & Construction 10 05-03-2010 10:32 AM
