Can I Use Leftover Pieces Of Batt Insulation On Walls - Insulation - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 1 Post By Nealtw
  • 1 Post By Yodaman
  • 2 Post By de-nagorg
  • 1 Post By romeojk27
Old 10-28-2018, 01:23 PM   #1
romeojk27's Avatar
Rewards Points: 14
Can I use leftover pieces of batt insulation on walls
Hi guys. Can I put pieces like this together into the bays below the windows?
If I cannot then I have to buy more insulation.
Any advice on what to do is appreciated.
I just pushed it all together in the bays so I can easily pull them out
romeojk27 is offline   Reply With Quote
Old 10-28-2018, 01:26 PM   #2
retired framer
Rewards Points: 364
Re: Can I use leftover pieces of batt insulation on walls
Yes that is fine.
romeojk27 likes this.
The Following User Says Thank You to Nealtw For This Useful Post:
romeojk27 (10-28-2018)
Old 10-28-2018, 02:13 PM   #3
Property Mgt/Maint
Rewards Points: 24
Might want to put some paper over the uncovered areas as a vapor retarder. Either extra paper from areas where you may have pulled the insulation off, or house wrap or even light tar paper will work.
[political signature removed]
Yodaman is offline   Reply With Quote
The Following User Says Thank You to Yodaman For This Useful Post:
Old 10-28-2018, 03:43 PM   #4
JUSTA MEMBER
Rewards Points: 98
In lieu of paper, I have used large trash bags, stapled to the studs, and Duct tape at the seams between the shorties.
Done quite a lot actually, if you take care of the airgaps, it works well.
ED
Yodaman and romeojk27 like this.
de-nagorg is offline   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
Old 10-28-2018, 09:45 PM   #5
romeojk27's Avatar
Rewards Points: 14
Thanks guys. Iíll clean them up and staple them down and I do have duct tape and a thick trash bag for the unfazed part. Thanks for the quick responses.
de-nagorg likes this.
Using attic insulation in interior walls. russd772 Insulation 6 08-16-2013 12:15 AM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 10:09 PM
Laying batt FG insulation over attic floor rlandry Insulation 3 12-10-2011 10:12 AM
Need opinions on insulation of basement walls mstemphoski Building & Construction 0 03-28-2011 10:15 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
