Bungalow Floor On Screwpiles - Insulation - DIY Chatroom Home Improvement Forum
Old 06-08-2014, 07:43 PM   #1
bungalow floor on screwpiles
so, I am building a bungalow on screw pile foundation, 2x10 joists on top of triple 2x12 beams.
What are the various methods of insulating the floor efficiently and effectively?
I intend to build the floor first and then the walls and then install the plumbing through the floor. For the perimeter I intend to have 2x12 insulated panels to the ground.
But for the floor it self where does the poly go in relation to the insulation, and what should I use for protection against rodents and animals getting into the floor? Radon protection?
How to build a properly insulated floor for the harsh Canadian winter?
wwsteel is offline   Reply With Quote
Old 06-08-2014, 08:00 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 812
Rigid foam across the bottom to thermally uncouple the framing. The type and thickness may eliminate the vapor retarder level requirements.
Old 06-08-2014, 08:18 PM   #3
ok, so basically I would crawl underneath the framed floor and install the strips where I can? what about the places of connection details, like where the joists rest on the beams? Or, should the joists be flush with the beams now?
Sorry, first build.
Old 06-09-2014, 06:16 AM   #4
Rewards Points: 812
Yes. Time to do this would be before the first platform is on for easy access but it sounds like you are past that.
You can cut and cobble and spray foam quite a bit on the corners to help with the insulation value.
What kind of brick is this called? craftsman bungalow stiksandstones Concrete, Stone & Masonry 3 03-30-2014 09:42 PM
Small bungalow help lims1988 Interior Decorating 1 05-19-2013 10:42 AM
Topping up a bungalow - order of operations mike416 Building & Construction 9 05-10-2012 08:17 AM
Addition of second level to bungalow jdever Building & Construction 2 02-17-2012 03:09 PM
First Home, 1929 Bungalow nhoc6131 Project Showcase 3 06-27-2011 05:01 AM
