Bonus Room Floor Spray Foam? - Insulation - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Windows on Wash
  • 1 Post By BlakeJ
Old 09-30-2016, 03:32 PM   #1
Rewards Points: 54
Bonus room floor spray foam?
I know the best way to spray foam a bonus room floor is to spray from underneath, directly on to the underside of the floor. But how much less effective would it be if you sprayed the top of the drywall from above, then added batt insulation, then installed the floor?
BlakeJ is offline   Reply With Quote
Old 09-30-2016, 08:33 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 928
Re: Bonus room floor spray foam?
Depending on the climate, spraying the foam to the bottom, with an air space, is the more effective approach. It allows the roomside heat in heating applications to circulate and warm the space below.
Bud9051 likes this.
Old 09-30-2016, 08:36 PM   #3
Rewards Points: 54
This will be in Texas, so I'm mostly concerned with cooling. The drywall is already in the garage below, but the bonus room floor is not in yet. I'm just curious if I could insulate it properly from above so I don't have to pull drywall.
TheoKiriopoulos likes this.
Old 10-01-2016, 07:20 AM   #4
Rewards Points: 220
Your approach should not be a problem in a hot climate as that is the same way a wall assembly is often insulated. Be sure to air seal all seams and penetrations into those cavities that the foam doesn't take care of.
Is the foam open or closed cell?
Bud
Bud9051 is online now   Reply With Quote
Old 10-01-2016, 07:27 AM   #5
Rewards Points: 928
+1
Still works. Be sure, as Bud stated, that air seal is done well. We worry about communication with the garage and fumes in bonus rooms type applications as much, if not more so, than energy loss.
Old 10-01-2016, 07:45 AM   #6
Rewards Points: 54
I was going to use closed cell. If I spray from above, I will still have room to add more insulation before I lay the floor. Do you guys think blown in cellulose would be better than batts?
Old 10-01-2016, 02:09 PM   #7
Rewards Points: 220
When additional air sealing is desirable the cellulose does a good job of covering everything. In your application, the spray foam will take care of most and some caulking of holes and seams the rest. Although I like cellulose I see no strong additional benefit here. For batt insulation, consider Roxul (mineral wool) very dense.
Bud
Trying to make my bonus room more comfortable 99ls1tj Insulation 4 07-30-2016 02:53 PM
Ceiling Insulation for my attic/new bonus room Jonathankoa Insulation 4 06-17-2015 07:27 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Bonus Room questions - FROG kamig1 Building & Construction 3 04-06-2010 08:29 PM
Bonus room drywall rhall31 Drywall & Plaster 3 01-18-2009 11:56 AM
