Blown Insulation To Exterior Walls - Good Or Bad? - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree2Likes
Old 11-20-2014, 07:57 AM   #16
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 826
Cellulose is fine. If both are done right, they are air barriers and should be fine when installed properly.
The Following User Says Thank You to Windows on Wash For This Useful Post:
HomeSealed (11-21-2014)
Old 11-21-2014, 01:18 PM   #17
Home Performance
HomeSealed's Avatar
Rewards Points: 718
+1. Cellulose is most commonly used in this application and will do a good job. It is UNANIMOUSLY preferred by pretty much the entire home performance industry, whose only motivation is to use the most efficient and effective methods and materials possible. The same can't be said for the "fiberglass contingent" and the massive corporate $$$ behind it, along with a few goofballs that fall for their propaganda. If you are not sure what I'm talking about, I'm sure that Nailbags will oblige in "enlightening" you.
Ultimately, as WoW stated, either will get the job done, cellulose will just do it cheaper and debatably more effectively.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 05-23-2017, 08:42 AM   #18
Rewards Points: 70
Re: Blown insulation to exterior walls - good or bad?
Hello all,
I just purchased an old 1800's farmhouse and am contemplating the same thing as spoken here. Unfortunately i will be paying for this as im sure the grant is long gone.
We have a 2 story 1700 sq home with wooden siding. Im sure plaster walls, there have been updates but from what i have found in my short time here, mainly just 1/4 over top.
All the windows are very old and am at the point where i need to decide when i replace whether to go replacement or new construction. My wife wants to keep as much character as possible and with some arched windows in the front this poses issues with the choice or replacement over new build. The frames show their age. I know this is in the wrong category, but figured i would share.
With the reading i have done it seems that some are for the blown in insulation and like others have mentioned, some are dead against it. I just want to save some money with heating. No AC we have baseboard boiler system.
All thoughts, advice and insight is greatly appreciated. I would post picture, but i do not have enough posts, which is annoying
Thanks,
Matt
msaramak28 is offline   Reply With Quote
Old 05-23-2017, 04:58 PM   #19
Rewards Points: 826
Matt,
Start a new thread and take a handful of pictures that you can post up. That will keep it separate and you will get more feedback to a new post with visuals.
Old 05-25-2017, 09:12 AM   #20
Rewards Points: 70
Wow,
I will get some pictures for you guys and start a new thread in a day or so.
Thanks,
Matt
Windows on Wash likes this.
Attic blown in insulation ChicagoVille Insulation 11 07-07-2014 04:22 PM
4" Trusses & ice dams; enough space for good insulation? ben5048 Roofing/Siding 9 09-23-2010 12:38 AM
Blown insulation questions cheese9988 Remodeling 12 09-10-2010 03:15 PM
Removing old attic blown in insulation and 52Caddy Remodeling 12 03-27-2010 11:19 PM
Has anyone used Green Fiber blown in insulation? pomelo Building & Construction 7 02-10-2010 07:17 AM
