Blow In Cellulose In Existing Walls - Insulation - DIY Chatroom Home Improvement Forum
Old 01-30-2016, 12:28 PM   #1
bryanp22's Avatar
Rewards Points: 364
Blow in cellulose in existing walls
Our house was built in 1946 and our closets are extremely cold. A couple years ago when I redid our bathroom shower the insulation in the walls basically fell apart upon me moving it slight to inspect it. I am considering hiring someone to blow in cellulose into my walls. Has anyone done that before? Was it worth it. Any ideas on how pricing is done?
bryanp22 is offline   Reply With Quote
Old 01-30-2016, 01:01 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 856
It has been done quite a few times.
What does the exterior cladding consist of and how is it constructed (layers, drywall, WRB, plywood, sheathing, etc.)? Effectively, you will be changing the wall characteristics, what is cold inside the wall, and the wall's ability to dry out.
All of these things must be taken into consideration when you do this and if it makes sense.
Old 01-30-2016, 02:34 PM   #3
Rewards Points: 1,858
Balloon wall constrution?
Just hate to see a home get insulated by blowing insulation inside the walls without it being opened up so you can see what your doing.
If it is old enough and it's balloon wall framing those walls are open from the basement all the way to the attic.
A huge fire hazzard because the walls act as a chimney during a fire.
There's no fire blocking at the top and bottom of the walls.
Blown in always leaves gaps under all windows, any blocking or diaganals in the outside corners can leave whole areas with no insulation.
Old 01-30-2016, 02:53 PM   #4
bryanp22's Avatar
Rewards Points: 364
We got new siding a couple years ago so now it's vinyl siding then thin layer of foam. Old siding underneath is cedar with felt underneath. Then 2x4 wall. Inside walls are finished with 3/8 drywall with 3/8 of plaster on top. The siding we replaced was actually aluminum. We left the cedar on the house.
Old 01-30-2016, 03:43 PM   #5
Sorry to hear that.
Going to working backwards now.
Should have been blocking at the bottom of the walls (if it was balloon wall framing) drilling holes in the old siding, insulating, then the fan fold and siding.
Even better yet using insulated siding.
Old 01-30-2016, 03:45 PM   #6
How much insulation is in the attic?
In your area it should be a minimum of R50 which is about 12".
Old 01-30-2016, 09:12 PM   #7
Rewards Points: 856
If the house hasn't been air sealed and insulated (attic) yet, I would start there.
That will have a larger impact on the total energy consumption and feel of the home.
As far as the walls goes, It sounds like it should be able to dry to the exterior with the wood siding still intact (assuming the wood siding isn't airtight or vapor impermeable because of paint or other covering).
Is it ok to blow insulation over existing fiberglass batts? pointer80 Insulation 1 12-21-2015 03:32 PM
Foam vs. Cellulose insulation in walls nhoj Insulation 10 12-19-2012 06:56 AM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 05:18 PM
Paint options for basement walls and floors 68tele Painting 8 10-28-2009 06:09 PM
Is regular wire ok to use if fishing through existing walls? slatergrl Electrical 10 02-29-2008 03:47 PM
