Black Speckled Pattern On Faced Insulation Behind Shower. Mold? - Insulation - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Taymar
Old 08-20-2018, 12:05 PM   #1
Rewards Points: 42
Black speckled pattern on faced insulation behind shower. Mold?
Hi all,
I've been investigating a damp odor in my upstairs room, and had the chance to poke an inspection camera into the faucet, dial, and showerhead openings of a tiled shower.
I noticed that the faced insulation behind it appears to have a fairly uniform black speckled 'pattern' covering it. My first thought was mold but there are a few things that don't add up for me:
1. none of the timber framing or surrounding unfaced insulation has this pattern on it
2. I don't get a strong odor from these openings, but do get a damp odor sometimes from the AC vents and from behind a couple of electrical outlets when the AC is blowing.
3. it doesn't seem like I can 'scrape' it off with the end of the camera.
I've attached a couple of pictures. the insulation (as best I can tell) is Owens Corning R-19 faced insulation.
Is there any other explanation for what this might be, or is it almost definitely mold?
thank you
Black speckled pattern on faced insulation behind shower. Mold?-dcim0040.jpg   Black speckled pattern on faced insulation behind shower. Mold?-dcim0042.jpg   Black speckled pattern on faced insulation behind shower. Mold?-dcim0047.jpg   Black speckled pattern on faced insulation behind shower. Mold?-dcim0050.jpg
Taymar is offline   Reply With Quote
Old 08-20-2018, 12:10 PM   #2
retired framer
Rewards Points: 676
Re: Black speckled pattern on faced insulation behind shower. Mold?
I don't think that is mold but mold would be lower in the wall if it is anywhere.
Old 08-23-2018, 07:59 PM   #3
Rewards Points: 42
Thank you very much. I found identical looking insulation in the attic and indeed, it was not mold. The facing on the insulation seemed to be two layers - one looked like black sheeting and one brown paper looking. As best I could tell, the black speckling is simply the black layer of facing showing through the brown layer in places.
Nealtw likes this.
Is this negligent or an ok plan (mold remediation) boondocks95 General DIY Discussions 53 12-30-2015 03:26 AM
Black Mold behind Baseboard dgarstang Plumbing 1 09-07-2015 09:52 PM
19" spaced joists - foil faced insulation? CWorth Remodeling 3 03-21-2009 12:26 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Window in Bathroom Shower: MOLD roztom Building & Construction 25 08-27-2008 05:42 PM
