Best Way To Overclad Exterior Wall With Fiberboard Sheathing With Insulation Foam? - Insulation - DIY Chatroom Home Improvement Forum
Old 06-09-2014, 11:14 PM   #1
Rewards Points: 133
Best way to overclad exterior wall with fiberboard sheathing with insulation foam?
I have an exterior wall with stucco that's in rough shape that I would like to overclad with 4 few inches of rigid foam insulation and a new layer of stucco or an EIFS-like polymeric equivalent. However I just found out today that the underlying wall sheathing is not plywood or OSB but rather fiberboard, and it doesn't take screws (on the plus side, the termites seem to hate it).
It seems like the only way to properly adhere the foam in this circumstance would be to screw it through the existing stucco and into the studs, but is it really possible to hit such small and invisible targets through four inches of foam and a thick coating of stucco? How likely is is that I would be able to hire anyone who could accomplish this? Is there another way this could work?
iLikeDirt is offline   Reply With Quote
Old 06-10-2014, 02:13 AM   #2
JUSTA MEMBER
Rewards Points: 152
With the proper experience the studs can be found.
And a stucco company has that.
Since you are in northern NEW MEXICO, I suspect that there are a few firms there that does this.
ED
de-nagorg is online now   Reply With Quote
Old 06-10-2014, 06:06 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 904
You are going to build a wall out 4"...?
That is going out a good ways. Make sure all the flashing and wall intersections are detailed out correctly.
Old 06-10-2014, 08:03 AM   #4
Rewards Points: 1,880
4"!
That's going to make it a nightmare to trim out the windows and doors without removing and reinstalling them.
The foam gets attached to the studs not the fiberboard.
Just look for the roofing nails in the sheathing to find the studs.
Old 06-10-2014, 12:04 PM   #5
Rewards Points: 133
Thanks everyone. The windows and doors are going to be replaced at the same time, and the wall is not a complicated shape.
Foam insulation on foundation arisley28 Concrete, Stone & Masonry 0 07-30-2013 01:03 PM
Pairing Rigid foam insulation with existing wall cavity Izaura Insulation 8 03-30-2013 07:56 PM
Insulation: foam or cellulose? wombosi Insulation 1 07-06-2011 08:20 PM
removal of exterior sheathing to apply spray-foam insulation from the outside raymaccallum Building & Construction 4 03-24-2011 05:52 PM
wall sheathing, foam board, insulation and house wrap dr.demento Building & Construction 10 10-18-2007 04:42 PM
