Best Way To Insulate Plank Construction? - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree3Likes
Old 01-27-2019, 08:37 PM   #16
Rewards Points: 36
Re: Best Way to Insulate Plank Construction?
Also would like to say thank you to everyone that chipped in their .02 cents. It's much appreciated for someone who will be doing changes like this room by room. Keep the info coming if you find anything. I will talk to my coworker who mentioned it tonight when I see him. I'm thinking he may have run into this when he renovated his house.
MKCoconuts is offline   Reply With Quote
Old 01-28-2019, 06:38 AM   #17
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 766
I would definitely NOT fill anything between those two planks. You will change the way that they dry out and that could be catastrophic in the long run. I think you best bet is as was mentioned previously. A framed wall in front of the plank wall.
I would put a thin layer of foam board that is attached to the wall and air sealed. I would thing frame the wall in front of it and fill with normal batt insulation. Wall can still dry to the exterior and the foam board will nearly totally eliminate any drying to the inside.
Old 01-28-2019, 07:06 AM   #18
Rewards Points: 36
I wasn't planning on filling inbetween, exactly for the reason you mentioned. There is no rotted wood, so it is obvious that any moisture that does make it's way there doesn't stick around for long.
I really hate putting a framed wall and losing that space, it would seem there is no other option unless someone who's an expert in this rare construction pops up and can point another direction. I am still going to explore the idea of pulling one plank at a time and installing a 2x4 in it's place. And then when time/money permits, remove the outer ones and replace them with OSB, wrap, insulation and new siding.
Old 01-28-2019, 08:46 AM   #19
Rewards Points: 766
Remember that the space we are talking about is about 8" of length and width respectively. To insulate the home and allow for the exterior cladding to last another lifetime, that isn't that punitive in my opinion. That said, you are definitely the boss here with regards to your own home.
Old 01-28-2019, 06:54 PM   #20
Rewards Points: 36
The bigger benefit to adding the frame is I have somewhere to run the electrical, as mentioned. And leaving one outlet in the room just won't do the trick.
I may go the route you mentioned with the foam board and air sealed and then the framing with bat insulation.
Old 01-28-2019, 07:56 PM   #21
Rewards Points: 22
See if you can find this magazine. OLD - HOUSE JOURNAL Vol XX1 , # 3 HOUSES WITHOUT FRAMES.
Technique of Plank Construction by Stephen B. Jordan page # 36 thru page # 41 this article should help you under plank framing.
Windows on Wash likes this.
ClarenceBauer is offline   Reply With Quote
Old 01-28-2019, 08:23 PM   #22
Rewards Points: 36
That was an excellent read. I can't believe that never popped up in any of my searches. It does answer a few questions and looks like I'm going to have to give up a few inches to put in insulation, which, I suppose is worth it if it helps keep the house warmer/cooler and saves some money on the energy bills. I will have to take the articles suggestion too and super insulate the attic, once all the knob and tube wiring is replaced with romex.
Old 01-29-2019, 05:59 PM   #23
Rewards Points: 36
So, after adding up cost of everything, I think I'd decided my plan. I'm going to put 2" rigid foam up (giving me a Rvalue of 12.9), some 1x3 furring strips to allow room for wiring and 1/2" drywall. This will require me to buy MC wire but this way will certainly warm that room up, give me the extra outlets I want, while sacrificing the least amount of space. Any one have objections or concerns with this route?
Old 01-29-2019, 06:23 PM   #24
retired framer
Rewards Points: 282
It is a strange house, pretty hard for anyone to tell you something is wrong.
Old 01-29-2019, 07:18 PM   #25
Rewards Points: 36
That it is. Odd enough, I am pretty sure my grandparents house is older but has normal stud walls and it's only 2 miles away! Haha. And while I do like the house, if money were no object, I'd tear it all down, dig out a full basement (right now half the house has a dirt floor basement, other half a crawlspace), and rebuild it nearly the same....just more modern and better insulated.
I'd just like to have everything I change as close to code as possible, though with such a house, could I be considered a gray area?
Old 01-29-2019, 07:38 PM   #26
retired framer
Rewards Points: 282
Your parents house is balloon framed and there are enough around that people know the pitfalls and the few improvement that should be made but with yours, you will just have to discover them as you go.
We did some work on a house where the whole house was built with solid 2x4s all nailed together. Electricians where making room for wires with a chain saw and we had too get a steel frame built for the HVAC register holes in the floor.
The inspectors all just walked around, shaking there head, smiling at each little way some one figured out some way of doing something and past everything first time.
Old 02-22-2019, 09:39 PM   #27
Rewards Points: 36
So I got pretty far insulating with rigid foam and got the wiring figured out. I had a friend who is an architecture engineer look at it and said I would be okay taking the inner planks out and studding the wall out.
Given that I got almost two walls done with just putting the rigid foam over the inner planks, I hate to back track. But I was wondering, does anyone see an issue if I were to remove the inner planks, put the rigid board against the outside planks (sheathing) and then stud out and use fiberglass insulation. Do so would eliminate thermal bridging and give a more proper way of running my electrical.
If I stud out, I do not want to leave the interior planks. Reason being that doing so will require me to move the current doorway over and if I can avoid that, I'd be a happy camper. It will also making window molding easier and keep the room a good size.
Old 02-22-2019, 09:58 PM   #28
retired framer
Rewards Points: 282
I think the outer planks are balloon from bottom to top of the house, so they are the structure, I don't see a problem with just adding a wall instead. Much like building wall in front of a brick wall . But at best I too am just guessing at what the builders had in mind.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 02-22-2019, 10:06 PM   #29
Rewards Points: 36
I'm more concerned with using the rigid foam on the interior side of it. I don't want it cause a moisture problem and rotting the wood since, like you said, that is the supporting area of the house.
If I had the money, I'd tear this down and rebuild with modern framing almost exactly the way it is now
Old 02-22-2019, 10:21 PM   #30
retired framer
Rewards Points: 282
The trick is to seal the inside so no house air can get back in there. Moisture condenses at the dew point and the dew point will be somewhere in the wall so just don't let moisture get to that spot.
Air leaks that let air travel right thru the wall are the worst.
figure 7-14
Luxury Vinyl Plank Flooring OutbackAnnie Flooring 11 06-26-2018 08:22 PM
Plank subfloor not breaking on joist mizquierdo31 Building & Construction 1 03-06-2018 07:06 AM
Plank flooring for new construction DidjaDewit Flooring 3 10-17-2012 04:56 PM
Books that teach the basics of construction - recommend them to me? costafinkel Building & Construction 13 08-04-2011 11:32 PM
