Best Insulation For Road Noise - Insulation - DIY Chatroom Home Improvement Forum
Old 12-02-2014, 08:43 AM   #1
Rewards Points: 28
best insulation for road noise
I have a large window that catches sound to much. New curtains cut it way down.....My home is 150 feet from the rd. highly, traveled rd.I was thinking 1" styrafoam for A 54'x 4' window.I accept the fact, i can't rid our bedroom from the all the noise,but knocking it down some more, would be great. Am i thinking along the right lines, or???????????----Please share what you think i could use? This will be a "press in fit" thumb tacks-being needed, if necessary.
Let me in on what you can? much appreciated here. bob s in mich
bsa_bob2 is offline   Reply With Quote
Old 12-03-2014, 10:23 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 818
Interior storm window with laminated glass is your best bet that you can see through.
Old 12-04-2014, 04:54 PM   #3
Rewards Points: 28
It would be rather expensive wouldn'
t it? The window is 5 feet wide...........Pella wood /double pane /glass?
Old 12-04-2014, 06:30 PM   #4
Rewards Points: 2,600
concrete_joe is offline   Reply With Quote
Old 12-04-2014, 07:40 PM   #5
Rewards Points: 818
Originally Posted by bsa_bob2
It would be rather expensive wouldn' t it? The window is 5 feet wide...........Pella wood /double pane /glass?
How much is a good night sleep worth?
Right rarely equals inexpensive.
The Following User Says Thank You to Windows on Wash For This Useful Post:
bsa_bob2 (12-05-2014)
Old 12-05-2014, 05:45 AM   #6
Rewards Points: 129
Problem with foam if there should ever be a fire foam will burn like napalm and cause a fire to spread very quickly.
For inexpensive go with the ear plugs.
jimn01 is offline   Reply With Quote
The Following 2 Users Say Thank You to jimn01 For This Useful Post:
bsa_bob2 (12-05-2014), Startingover (12-06-2014)
Old 12-05-2014, 08:09 AM   #7
Rewards Points: 28
Used ear plugs last night! worked quite well,now to stop waking up to pee 5 times a night , i will then get my necessary sleep, to stay awake the whole next day. Getting age isn't fun bob s thanks to all.Merry Christmas too
bob s
Old 12-06-2014, 09:25 AM   #8
Rewards Points: 108
cement board would work. 2 or 3 pieces cut to size and a little gap between them. somehow held into place.
Fix'n it is online now   Reply With Quote
Old 12-06-2014, 11:01 AM   #9
150ft away? can you build sound screens ~75ft away from window. they can be made attractive looking and you can plant some small trees to help hide it. how high up is the window from street level?
we would need to know what the surroundings are near the source of the noise, but i suspect most of the sound is direct from vehicle and contact with the pavement. reflecting sound needs to be evaluated, etc.
can your window accept a storm pane/panel?
Old 12-06-2014, 12:32 PM   #10
Rewards Points: 48
There used to be windows that were more soundproof than reg windiws. Nice for anyone living near an airport.
I'm near a road with traffic and filled that side of the yard with dense shrubbery which helps suppress the sound. Plus put a 6' wooden fence along that side.
Startingover is online now   Reply With Quote
Old 12-06-2014, 01:01 PM   #11
Ole Wood Worker
BigJim's Avatar
Rewards Points: 22
Might try a sound suppressing machine, I have heard they do work, but I can't say first hand.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 12-07-2014, 01:30 PM   #12
the scale of the device is likely too costly and cumbersome for this specific issue.
Condenser fan noise and then blade breaks. whotheguy HVAC 11 09-30-2013 07:59 PM
Insulation maitenance after remodel k2000lbs Insulation 10 02-19-2012 10:04 AM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 10:09 PM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
