Beginner Question - Insulation - DIY Chatroom Home Improvement Forum
Old 07-19-2016, 12:20 PM   #1
Rewards Points: 101
Beginner Question
Putting up some insulation on a few walls in NYC. Trying to get an idea of the suggested brand/type. Lowes has Owens Corning R13, R19, and R30. Also, what is the recommended staple type. Thanks in advance.
jte1130 is offline   Reply With Quote
Old 07-19-2016, 12:35 PM   #2
JUSTA MEMBER
Re: Beginner Question
That is a decent brand of insulation.
I use an ARROW T-50 Stapler to tack up the stuff. You only need the 1/4 inch staples for this, if you staple the paper to the studs.
ED
de-nagorg is online now   Reply With Quote
Old 07-19-2016, 01:01 PM   #3
Rewards Points: 4,864
Fiberglass loses R value if it's compressed, so get the size which fits your wall cavities best.
Have you looked at mineral wool at all? Common brand is Roxul.
stick\shift is offline   Reply With Quote
Beginner Saw Question: Cut ends snapping off 2x4s before cut is finished StoopidMonkey81 Carpentry 15 01-05-2015 08:48 PM
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 01:48 PM
Plumbing for new shower kit question noviceshock Plumbing 6 03-02-2013 08:11 PM
quick question on closet flanges corman Plumbing 3 11-18-2012 03:18 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
