Batts In Ceiling That Already Has Foam? - Insulation - DIY Chatroom Home Improvement Forum
Old 02-12-2018, 04:54 PM   #1
Rewards Points: 4
Batts in ceiling that already has foam?
A common story, cold living space above the garage.
I took out the batts in the drop ceiling of the garage and had a contractor come in and spray foam the underside of the deck (bedroom floor/garage ceiling). They did the walls too. I also put a natual gas furnace in the garage and intend to keep it around 15C/60F in the winter.
I am about to drywall the drop cieling. There will be about 2' of space from the foam to the drop ceiling and was thinking of adding batts up there to beef up the insulation.
Would this be acceptable? Any issues with mold? I did a drawing to better illustrate...
Treehorn is offline   Reply With Quote
Old 02-12-2018, 05:34 PM   #2
Guapo
Rewards Points: 11,950
Re: Batts in ceiling that already has foam?
I don't see how any insulation there would help the space above the garage. How is that space heated?
Guap0_ is offline   Reply With Quote
Old 02-12-2018, 05:37 PM   #3
Rewards Points: 246
How thick is that rigid insulation?
Will you be bringing in wet or snow covered vehicles into that garage space?
What is your climate region?
With closed cell foam you have a vapor barrier. Adding another below would probably not be good. But, if you are introducing a lot of moisture into the garage you are in a pickle.
Fill us in.
Bud
Bud9051 is online now   Reply With Quote
Old 02-12-2018, 05:55 PM   #4
retired framer
Rewards Points: 864
Once the lower insulation gets cold which is just time in cold weather. There is no heat to warm it up. I would put new insulation in contact with the foam. Every house up here as a room over the garage and they use glass bats and drywall. the drywall has to be taped and painted. I have never run across a problem.
Old 02-12-2018, 06:06 PM   #5
Rewards Points: 4
i wont be bringing cars into the garage because i am turning it into a a bit of a man cave. Only source of moisture would be a snowblower. The house is forced air and the garage will be natural gas unit heater ceiling mount.
Old 02-12-2018, 06:10 PM   #6
retired framer
Rewards Points: 864
Then you are more concerned with w perimeter for insulation and the ceiling for sound proofing.
Old 02-12-2018, 06:13 PM   #7
Rewards Points: 4
That's correct. I may want to be able to keep the garage cooler than the house to save on energy but never freezing because i am adding a urinal.
Old 02-12-2018, 06:14 PM   #8
retired framer
Rewards Points: 864
Walls insulated?
Old 02-12-2018, 06:15 PM   #9
Rewards Points: 4
All sprayfoamed
Old 02-12-2018, 06:17 PM   #10
Rewards Points: 4
And insulated doors but they are only R12
Bulb/fixture that hides ceiling imperfections stripedbass Electrical 16 01-08-2017 01:49 PM
3 way switch with z wave micro switch help emax08 Electrical 3 11-01-2016 05:51 PM
Finishing Basement - flip existing R-30 batts in ceiling? pburgh19 Insulation 3 12-17-2015 12:06 AM
Attachment strategies for Rigid foam board over plaster ceiling frtools Insulation 5 10-11-2013 09:35 AM
Foam board over batts juststarted Insulation 3 12-13-2011 12:12 PM
