Basement Rim Joist Insulation In Tight Space - Insulation - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Logan176
Old 07-01-2016, 09:54 AM   #1
Rewards Points: 60
Basement Rim Joist Insulation in Tight Space
I'm almost done insulating my rim joists with 2" XPS foam boards in preparation for a basement renovation. There is a 12' span where the access is so tight that it's impossible to slide in the foam boards.
I might be able to push in some batt insulation, but do you think I can use spray foam from a can?
If I slide the spray nozzle up from the bottom, I could probably reach about halfway up to fill the narrow cavity with foam. I could also drill small holes in the joist, just big enough to get the spray foam nozzle through, to take care of the top half of the cavity.
Your thoughts?
Logan176 is offline   Reply With Quote
Old 07-01-2016, 10:58 AM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: Basement Rim Joist Insulation in Tight Space
The trouble I have had in the past includes needing the can to be upside down when spraying. Also, it takes several cans and will get expensive, even with the large containers.
Talk to a local Spray Foam guy and see what he would charge if you let him decide the schedule for a day when he has an opening while in your area.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 07-01-2016, 12:07 PM   #3
Rewards Points: 60
Unfortunately, I really don't have a lot of trust in spray foam that is mixed in a van in my driveway. I am still dealing with the aftermath of a poorly installed spray foam job in my attic. I understand the cans will be expensive, but at least I know they are all mixed the same way.
jlhaslip likes this.
Old 07-01-2016, 03:02 PM   #4
jlhaslip's Avatar
Rewards Points: 708
Too late for this project, but when I layout a subfloor, I watch for exactly this issue.
After having to deal with small joist spaces at the rim board a few times, I start to layout the joists except the last one or two and I lay those out from the opposite side, creating more room above the concrete for electrical and insulation issues. Still meets code as long as the spacing does not exceed the designed c/l's.
Old 07-01-2016, 09:42 PM   #5
Rewards Points: 192
Not sure what that joist is, 2x10? but I suspect a 2x8 would do just fine. A reciprocating saw and a nasty blade would give you all the space you need. If you would feel guilty reducing the depth, then sister something along side of it. Being that close to the outside wall there really isn't a load concern.
Bud
Bud9051 is online now   Reply With Quote
Crawl Space Insulation in NWT Canada too-cold Insulation 3 11-10-2012 02:11 PM
Vapor barrier issue between crawl space and conditioned basement gregsenne Insulation 3 10-11-2012 11:53 PM
Basement Exterior Above Grade Insulation purpasadu Building & Construction 6 02-28-2012 04:42 PM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 10:09 PM
Crawl Space Questions mark2741 Building & Construction 1 12-23-2011 11:20 PM
