Basement Insulation R Vaule - Insulation - DIY Chatroom Home Improvement Forum
Old 08-08-2015, 11:04 AM   #1
Rewards Points: 463
Basement insulation R Vaule
I am still in the planning stages of my basement bathroom install. I had asked the county inspector what is required to be up to code. This is his email
"The answer depends on the exposure of the basement walls to the exterior.
R-5 is required except the walls that are more than fifty percent above grade shall be insulated as a wall – R-13".
My basement is fully underground except for about 1 foot is above the soil. With that I will be to code using R5?
cincinnati guy is offline   Reply With Quote
Old 08-08-2015, 08:21 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 856
You may want him to clarify that answer. Your frost line is about 20" where you are.
Old 08-09-2015, 08:42 AM   #3
Rewards Points: 14
Total wall area in square feet divided by amount above grade == % above grade. Frost depth was not mentioned in your post and is generally below grade.
I doubt your codes are more lenient than ours and as I understand the rules basements must be studded up with 2 x 4 walls here.
Home HVAC systems are rarely sized to heat an unfinished basement.
Insulation is relativity cheap and its use is generally a 'no-brainer'.
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is offline   Reply With Quote
Basement Exterior Above Grade Insulation purpasadu Building & Construction 6 02-28-2012 04:42 PM
Insulation in basement floor joists and integrated garage speedster1 Building & Construction 3 12-07-2010 05:44 PM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 07:36 AM
basement insulation advise needed bmartin5150 Building & Construction 1 04-27-2009 04:56 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
