Basement Insulation- Put Extra? - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree2Likes
Old 01-06-2018, 08:51 PM   #16
retired framer
Rewards Points: 628
Re: Basement Insulation- put extra?
Originally Posted by NotYerUncleBob2 View Post
There's actually a lot of debate on the value of venting crawlspaces these days. Best practice now seems to lean more toward insulating, sealing, and conditioning the crawlspace rather than venting it.
I've never built a house on stilts, but I'd be inclined to close up the bottom and treat it the same as if it was a wall.
It is more about code and best practice where the house is.
Old 01-06-2018, 09:54 PM   #17
Rewards Points: 1,060
I know that Canadian code specs poly in the walls, or did, or still does? But south of the border we don't use it at all in walls or ceilings. We do have vapor retarders like the faced fiberglass but that's about it on the inside of the house. I guess the movement is now to stop the vapor at the outside of the house and then to prevent the differential that could cause condensation inside the walls.
NotYerUncleBob2 is offline   Reply With Quote
Tags
basement , insulation , insulation basement
Sub Basement Insulation ken57 Insulation 0 11-13-2017 08:32 PM
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
basement insulation - condensation behind the batt insulation natalie Building & Construction 3 01-31-2010 10:19 AM
Basement Insulation and humidity control mcwolfe6 General DIY Discussions 11 01-28-2010 06:02 PM
Basement Insulation raulakh Building & Construction 2 10-13-2009 12:36 AM
