Basement Insulation And Framing - Insulation - DIY Chatroom Home Improvement Forum
Old 01-08-2015, 11:06 AM   #1
Rewards Points: 2
Basement Insulation and framing
We moved into a foreclosure about 2 years ago and are finally ready to tackle the basement. I had plans on applying 2" rigid foam board to the foundation walls and building a 2x4 wall in front with fiberglass unfaced insulation. But the small above grade wall on top of the foundation has me stumped. Should I bring the 2" rigid foam all the way up and cover the partial framed wall? Open to suggestions. Thank you!
Basement Insulation and framing-imageuploadedbydiy-chat1420735973.258113.jpg
Jkf1983 is offline   Reply With Quote
Old 01-08-2015, 11:22 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
Pull out that fiberglass, seal the backside of the sheathing so that there is no air loss, install unfaced insulation, and then you can bring your foam all the way up.
Old 01-08-2015, 07:15 PM   #3
Rewards Points: 2
Will do thank you! Would you do 2" or would that be overkill?
Old 01-09-2015, 09:45 AM   #4
Rewards Points: 906
Not at all.
Do it once and do it right.
Old 01-09-2015, 04:24 PM   #5
Registered User
Rewards Points: 526
Welcome to the forums! Where are you located?
Gary
Basement finishing- Framing/ insulation question csd11 Remodeling 2 07-28-2014 07:18 AM
Basement Framing and Insulation und4512 Building & Construction 8 03-31-2013 01:09 PM
Basement insulation after framing Trleslie Insulation 1 10-19-2012 01:42 AM
basement framing / insulation question in storage portion of finished basement. cobra5laddict Insulation 5 03-22-2012 09:59 PM
Drywall, insulation, framing and basement. Timothyv Building & Construction 7 03-31-2011 12:12 AM
