Basement Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 12-15-2018, 02:42 PM   #1
Rewards Points: 2
basement insulation
My basement has 2x4 stud walls along the exterior block walls. The 2x4 wall is set off the block by about a 3/8 inch. I dont think there has ever been an issue with water or moisture.(just recently moved in) Would it be safe to use fiberglass insulation before drywallig? Or do I have to go with rigid? Thanks
patjd is offline   Reply With Quote
Old 12-15-2018, 03:15 PM   #2
Collector of tools
Rewards Points: 188
Re: basement insulation
I'm not qualified to answer the question about whether it's safe to use fiberglass. But in my last 2 homes I used rigid against the concrete followed by fiberglass between the studs. That's more expensive but both basements were dry, warm and didnt have that musty smell. On this house I bought used/scrap rigid from a guy on craigs list who salvages it from demolitions.
schreibdave is offline   Reply With Quote
Old 12-15-2018, 03:29 PM   #3
Rewards Points: 24
Here the FG would meet code and it what I would use. I don't know where you are or what your local code might be.
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is online now   Reply With Quote
Old 12-15-2018, 05:17 PM   #4
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,888
Would it be safe to use fiberglass insulation before drywalling?
I'd suggest Roxul.
The concern is having a vapor barrier in there too.
Even if you don't need the extra R's the XPS does the vapor.
Old 12-15-2018, 05:36 PM   #5
retired framer
Rewards Points: 596
That is like the wall we build and they use either FG or safe n sound and a 6 mill vapour barrier and then drywall , the barrier is to keep moist house air from condensing on the cool fountain.
Tags
basement , fiberglass insulation
Sub Basement Insulation ken57 Insulation 0 11-13-2017 08:32 PM
Basement Exterior Above Grade Insulation purpasadu Building & Construction 6 02-28-2012 04:42 PM
Insulation in basement floor joists and integrated garage speedster1 Building & Construction 3 12-07-2010 05:44 PM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 07:36 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
