Basement Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 09-14-2015, 10:35 AM   #1
Rewards Points: 455
Basement Insulation
Gonna finish a small 12x12 basement (2 outer walls and above ground) with 2x4's and drywall. Whats the best insulation method for the wall ?
Cletis is offline   Reply With Quote
Old 09-14-2015, 11:01 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 856
Where's the home?
There are quite a few good to basement insulation threads in this sub forum. Most effective strategies will entail the use of some rigid foam board against the masonry wall and a well sealed rim joist.
Old 09-14-2015, 11:22 AM   #3
Rewards Points: 455
Originally Posted by Windows on Wash View Post
Where's the home?
Brevard,NC Temperate climate
Old 09-14-2015, 11:51 AM   #4
Rewards Points: 856
There's a good thread about three or four items down where man is asking for insulation advice about a basement in North Carolina as well.
Look for "Advice on...
Old 09-14-2015, 08:44 PM   #5
Registered User
Rewards Points: 526
Here; http://www.diychatroom.com/f103/advi...ection-313553/
But is your "basement" a entirely above-grade?
Gary
Basement Exterior Above Grade Insulation purpasadu Building & Construction 6 02-28-2012 04:42 PM
Insulation in basement floor joists and integrated garage speedster1 Building & Construction 3 12-07-2010 05:44 PM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 07:36 AM
basement insulation advise needed bmartin5150 Building & Construction 1 04-27-2009 04:56 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
