Basement Blanket Insulation Framing - Insulation - DIY Chatroom Home Improvement Forum
Old 10-26-2017, 10:37 AM   #1
Rewards Points: 24
Basement Blanket insulation Framing
Hello,
After much consideration, I decided to leave my white blanket insulation up in my basement, and frame in front of it. Now, I have put drywall up in one room, and took the advice from this video:
Basically, it says that if you keep the blanket wrap up, you simply fill the new stud wall with an unfaced insulation.
I am a bit paranoid now, and was wondering what the folks of this great forum think? Will everything be ok if I continue on with Roxul? Here is a pic of the wall I am working on now:
coyotethrust is offline   Reply With Quote
Old 10-26-2017, 10:44 AM   #2
retired framer
Rewards Points: 890
Re: Basement Blanket insulation Framing
You are good as long as you don't have two vapour barriers.
The Following User Says Thank You to Nealtw For This Useful Post:
coyotethrust (10-26-2017)
Old 10-26-2017, 10:49 AM   #3
Rewards Points: 24
Thanks Neal! How do you feel about basement ceiling insulation - do or don't?
Old 10-26-2017, 11:08 AM   #4
retired framer
Rewards Points: 890
If you are going after sound, sure but use resilient channels too
Make sure pot lights are rated for insulation.
Old 10-26-2017, 11:55 AM   #5
Rewards Points: 276
Doesn't seem fair for you to ask us for the OK on an approach that depends a lot on how the foundation was built and is performing. I checked your other posts and didn't see any prior basement discussion.
The plastic covered blanket insulation (I assume covered on both sides) will act as a vapor barrier and eliminate any drying to the inside. The result will be the inside surface of the foundation and the outside surface of the white plastic will slowly accumulate moisture until it matches the moisture in the ground outside.
Here is a link that discusses the issues related tot the diaper insulation, photo #3.
https://buildingscience.com/document...ts?full_view=1
Bud
Bud9051 is online now   Reply With Quote
Old 10-26-2017, 12:28 PM   #6
Rewards Points: 24
Bud
Hi Bud,
To elaborate, my foundation walls are poured, with a waterproofing membrane on the outside. There is also drain tile running back to the sump along the perimeter. The insulation wrap is only faced with the plastic, not covered on both sides.
Thanks for the link.
Old 10-26-2017, 12:57 PM   #7
Rewards Points: 276
Let me apologize up front and disclose, I HATE BASEMENTS.
I'll try to be short.
The exterior membrane is good, but moisture comes in both liquid and vapor forms and the vapor passes right through concrete, vertically as well as horizontally. For a dry basement that membrane would run down the wall, under the footing, and connect to a similar material under the slab. Almost never done so moisture vapor can still migrate up behind that insulation and accumulate.
Moisture can also come from the air inside the basement if that air finds a way past the plastic and reached the cold foundation.
The guidance provided in that link and others are not a guarantee that you will have problems, just that the risks are slightly higher than their preferred approach with rigid foam against the foundation.
Your nose will probably tell you if a problem develops, the old basement smell. Very few finished basements avoid that end, thus my dislike for them.
Best,
Bud
Old 10-26-2017, 01:14 PM   #8
retired framer
Rewards Points: 890
Bud< if there is a problem it will show up in the first few months. With more insulation it is less likely to wick moisture and with drywall, there is less of a chance of warm moist air getting to the concrete. I would sooner see what we do here. Works fine but it is closer to this than foam. We build a wall just like this and insulate that and add a vapour barrier leaving a space between insulation and concrete.
Foam boards usually will not work on a concrete wall inside because it is not smooth like a block wall so the choice would be sprayed foam. No system will protect against a leak.
Old 10-26-2017, 05:55 PM   #9
Rewards Points: 24
So if I want save money, is it ok to go with unfaced fiberglass? Or should I stick with Roxul? Thanks!
Raleigh basement insulation Todd1561 Insulation 5 01-14-2014 07:44 AM
Basement Wall Insulation jtroxel Insulation 4 12-30-2013 10:04 PM
basement framing / insulation question in storage portion of finished basement. cobra5laddict Insulation 5 03-22-2012 09:59 PM
2x6 insulation in 2x4 framing Yorkspy Building & Construction 10 12-09-2009 12:21 PM
Basement Insulation raulakh Building & Construction 2 10-13-2009 12:36 AM
