Baffles In Unevenly Spaced Cathedral Ceiling Rafters - Insulation - DIY Chatroom Home Improvement Forum
Old 12-28-2017, 12:34 PM   #1
Rewards Points: 172
Baffles in unevenly spaced cathedral ceiling rafters
I am going to be insulating a sloped portion of my ceiling.
I need to install baffles to provide venting from soffits to the upper attic space (1.5 story construction).
It's an old house and the rafters are not exactly on 24" centers. Is it a problem if, in some cases, the baffles to not extend quite to the inside of each rafter?
This is the type of baffle I am thinking of using:
https://www.homedepot.ca/en/home/p.2...000136854.html
They seem to already be designed to not provide a vent channel across the entire rafter bay.
As you can see, there is a spot in the middle where there is no venting, and there's no venting on the edges. In these spots, the insulation is basically in direct contact with the roof. Is it that big a deal, then, if in some wider bays, the vents don't touch the inside of each rafter?
jmetrail is offline   Reply With Quote
Old 12-28-2017, 12:41 PM   #2
retired framer
Rewards Points: 976
Re: Baffles in unevenly spaced cathedral ceiling rafters
That is close enough, it will be fine.
Old 12-28-2017, 12:42 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,054
It should be fine. If you are concerned about it, you can make your own, but most folks will just go with the store bought units.
They are never airtight so its not a big deal.
Old 12-28-2017, 01:05 PM   #4
Rewards Points: 326
The hard part when insulating the slope is getting enough insulation to meet codes. I'm not familiar with your requirement but most installs require increasing the depth significantly. Besides being code required you are in a very cold climate so more is better.
Bud
Bud9051 is online now   Reply With Quote
Ventilated Cathedral Ceiling "Open or Closed Cell" ? brulin Insulation 2 07-16-2012 11:40 PM
cathedral ceiling insulation charlie1025 Roofing/Siding 7 07-10-2012 11:57 AM
ventilation baffles in cathedral ceiling HHac8014 Building & Construction 10 05-03-2010 10:32 AM
Cathedral ceiling ventilation dpreznik Roofing/Siding 2 10-31-2006 10:18 AM
Rafter Thrust / Cathedral Ceiling sseeley Carpentry 8 10-06-2005 11:19 AM
