Baffled Over Baffles - Insulation - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-15-2016, 10:56 AM   #31
Rewards Points: 378
Ok thanks!
Now another stupid question
Does every rafter section need a baffle even if there isn't a vent from below??
Alumifab is offline   Reply With Quote
Old 02-15-2016, 11:10 AM   #32
Rewards Points: 312
@ AL "Does every rafter section need a baffle even if there isn't a vent from below??"
Yes, the objective is to cool the bottom of the roof and move that heat out, not just provide a path for air to get into the attic above.
I am also assuming that the soffit space is common where a few vents will be able to provide air to all rafter channels.
Bud
Bud9051 is offline   Reply With Quote
The Following User Says Thank You to Bud9051 For This Useful Post:
Alumifab (02-15-2016)
Old 02-15-2016, 08:19 PM   #33
Registered User
Rewards Points: 526
FG wrapped in a plastic bag also works... though in the one pic I don't see any insulation on the other side of your plastic-wrapped truck line... just the baffle above, am I missing something?
Gary
Attic insulation quotes, to add baffles or not? CaptJackSparrow Insulation 4 03-04-2015 06:35 PM
Proper Vent Baffles: To be continuous or not? jcarlan Roofing/Siding 7 12-27-2011 08:56 PM
Insulation & Baffles Bruce50 Insulation 1 03-15-2011 08:49 PM
i'm baffled...too many baffles? DangerMouse Building & Construction 10 02-04-2009 03:56 PM
Baffled about attic baffles. BugsDad Building & Construction 3 11-10-2008 04:03 PM
