Is This A Bad Idea ? - Insulation - DIY Chatroom Home Improvement Forum
Old 11-28-2014, 09:19 AM   #1
Rewards Points: 352
is this a bad idea ?
i am just wondering about this, as idk if i will ever do the basement.
block foundation 1/2 below grade. then 1" xps, then, turn the 2x4's sideways and install, then idk what insulation in the 1 1/2" space . than drywall.
i would be concerned with taking up to much space.
Fix'n it is offline   Reply With Quote
Old 11-28-2014, 09:45 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,022
You trying to preserve wall space? Not sure that the 2" less on the 4 sides will amount to that much. Easier to run wires and mechanicals in a full stud wall.
Old 11-28-2014, 10:02 AM   #3
Rewards Points: 352
i wouldn't want to make the room much smaller. so yeah, in some places 2" would be a lot. perhaps i will mock something up and see how it is. mechanicals = not any. wires, a few outlets, and i think i can run emt inside xps ?
Old 12-18-2014, 09:23 PM   #4
Registered User
Rewards Points: 526
1"XPS is a bad idea, unless you want condensation there, MINIMUM code in your location is R-10, not counting exposing (for wire runs) the concrete to room air for problems; http://energycode.pnl.gov/EnergyCode...state=Illinois
Gary
an idea for siding a shed/studio forresth Building & Construction 0 09-08-2011 07:48 PM
Carve toekick to make heater vent grill. Bad idea? mudworm HVAC 0 08-31-2011 12:27 PM
12-18" Spacing Between Foundation And Paver Patio Bad Idea? ErikU19 Landscaping & Lawn Care 3 04-09-2011 08:20 AM
Garage Electrical Idea cooper4x4 Electrical 2 01-13-2010 06:21 PM
feedback on business idea Jack000 General DIY Discussions 18 12-20-2009 08:01 AM
