Attic Ventilation Problem - Insulation - DIY Chatroom Home Improvement Forum
Old 05-07-2015, 04:28 PM   #1
Attic ventilation problem
A couple of years ago, I had an attic contractor insulate the attic with blown insulation and replaced a broken attic fan. Back in January of this year, we had a new water heater installed and found out that it was backdrafing (may have been a pre-existing condition). After a long process of elimination, we completely disconnected the attic fan, eliminating the backdraft. I was told by a contractor that I need an additional 10 mushroom vents. My house has no soffit vents. Will this fix the issue? Would the installation of the new water heater cause the backdraft?
Coldcity80 is offline   Reply With Quote
Old 05-07-2015, 06:01 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 826
Where is the water heater located? In the attic or inside the conditioned space?
If it inside the conditioned space, that indicates (along with the removal of the fan and opting for passive ventilation) that there is too much communication between the conditioned space and the attic.
How are you planning on supplying additional intake air? More exhaust without intake will not necessarily solve the back-drafting issue.
Granted, the lack of mechanical pull will, in all likelihood, solve the issue but too much exhaust without intake, can create a similar pressure issue in the home.
Old 05-07-2015, 06:44 PM   #3
Registered User
Rewards Points: 526
No, backdraft is caused mainly by powered attic exhaust ventilation, you need more supply vents; http://www.nachi.org/attic-ventilati...s-part1-25.htm
http://www.energyvanguard.com/blog-b...Are-a-Bad-Idea
Where are you located?
Gary
PS. Welcome to the forum!
Old 05-07-2015, 07:00 PM   #4
Rewards Points: 1,858
10 mushroom vents!!
Why?
A ridge vent would vent the whole roof, less work and cost less to install.
No form of soffit vents then any form of roof venting is not going to be much good.
Old 05-07-2015, 07:20 PM   #5
I live in Chicago.
I only have about 3 mushroom vents and an unpowered attic fan. Water heater is in he basement. I'm out of options here.
So, a ridge vent would be best??
Old 05-07-2015, 07:30 PM   #6
Or, what is my best option for intake vents in this case? Soffit vents aren't an option.
Old 05-07-2015, 10:27 PM   #7
Rewards Points: 826
Depends on the style, layout, and overhang situation.
What do you have?
Old 05-07-2015, 10:32 PM   #8
It's a raised ranch, mid-50's, no overhang. Just a couple of mushroom vents
Old 05-07-2015, 10:34 PM   #9
What do you have?
Old 05-08-2015, 04:24 AM   #10
Rewards Points: 826
Any chance you could post a picture? I'm not a huge fan of mushroom vents down low at the eaves because I never like popping a bunch of holes in the roof on the low side.
There are a handful of options to allow for some eave venting.
There are some vented facia board designs and strip vents for the roof deck that all work. Those are just a couple of options.
Old 05-08-2015, 07:28 AM   #11
Rewards Points: 1,602
I'd rather not add 10 new possible leak locations to my roof. A ridge vent should be a much better option.
mikegp is offline   Reply With Quote
Old 05-08-2015, 08:09 PM   #12
Rewards Points: 826
A ridge vent without intake doesn't solve the issue in total though.
Old 05-08-2015, 08:20 PM   #13
That's the issue here:
I HAVE NO INTAKE VENTS!
F'n old Chicago homes
Old 05-08-2015, 08:30 PM   #14
Property Mgt/Maint
Rewards Points: 24
Exclamation
No and it can make it worse. If the ridge vents are starved for air from lack of intake it can cause negative static pressure within the house making the back drafting problem worse.
The best scenario is balanced soffit (or other the means of low roof intake) to ridge vent. By balanced I mean do the math. Vents have a NFVA rating that tells you how much ventilation per foot you are actually getting.
NFVA of First Soffit + NFVA other side soffit = NFVA of ridge.
This is minimum. If you can get to 60 / 40 split with more intake, some say better yet
[political signature removed]
Yodaman is offline   Reply With Quote
Old 05-09-2015, 06:42 AM   #15
Property Mgt/Maint
Rewards Points: 24
Regarding your intake vents, IMO use under shingle vents. The vents should be placed as low as possible on the roof.
Pending how deep your blow-in insulation is in relation to the vent it may require attic baffles to keep the air flow open.
With this vent system in place all other vents in the roof should be capped. And no fan.
Attic ventilation confusion jlmran Insulation 6 01-05-2014 05:06 PM
Wooden Soffit/Aluminum Soffits + Attic ventilation Carling Roofing/Siding 14 06-10-2013 01:27 PM
Air sealing, ventilation, and attic insulation project-need advice Badfish740 General DIY Discussions 4 06-01-2011 06:48 AM
Attic Ventilation in 1928 Bungalow stephensandlin Roofing/Siding 1 07-09-2009 11:16 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 08:10 PM
