Attic Insulation / Vent - Insulation - DIY Chatroom Home Improvement Forum
Old 10-04-2015, 10:52 PM   #1
Rewards Points: 229
If modern builders always install the plastic/styrofoam vent chutes designed to staple where the truss rests on the top plate, doesn't this cause more intake ventilation than exhaust?
Or is this only the process because the true factor is determined by the square inches of soffit venting?
I don't see a faster/more economical way to allow venting but also prevent blown in insulation from closing the gap.
AlphaPilot is offline   Reply With Quote
Old 10-05-2015, 05:54 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 842
Not at all.
Venting at the soffit depends, as you referenced, on the NFA rating of the soffit and the exposure.
Most homes, given the layout, should be heavy on the soffit/intake provided they are open and unblocked by attic insulation.
Old 10-05-2015, 08:19 AM   #3
Rewards Points: 229
If I have every truss space open for venting I calculated it would be 3-4 times more nfa than my ridge vent. I assume that wont matter too much as long as my soffit nfa matches the ridge vent nfa. Yes?
It seems silly to leave every gap open if I don't need to. It cost 2 to 3 bucks per plastic vent chute to keep insulation from blocking the gap.
Old 10-05-2015, 08:35 AM   #4
Rewards Points: 842
$2-3 per chute?
You doing this or having someone else do it?
You cannot have insulation in that area whether or not you need the venting.
Old 10-05-2015, 10:05 AM   #5
Rewards Points: 229
Myself, the cheap ones are $1 or so but I feel they will deteriorate. I have approximately 90 cavities that will need filled. I realize air needs to flow, but if I don't have a vented soffit in the vicinity of the baffle, I wondered if it would be more efficient to not use a baffle in that location. If I don't have the need for venting there, I can fill insulation further in that area. I do have a raised heel truss so it's not as much of a concern for the extra insulation right at the kneewall.
Old 10-06-2015, 02:02 PM   #6
Registered User
Rewards Points: 526
"If modern builders always install the plastic/styrofoam vent chutes designed to staple where the truss rests on the top plate, doesn't this cause more intake ventilation than exhaust?"---------------- no, it is the size of the actual soffit opening minus the screening/louvers for your NFVA per unit.
The system should be balanced- 50/50, ---- not 60/40 or 70/30 as this leads to greater convective loops (and more moisture deposited) in the summertime. With more soffit inflow (cooler air) pushing the warmer (from room (house-stack effect) below/roof solar gain) air out the top exhaust, it would create a bottle-neck effect in the convective loop swirling around up there, getting even larger, robbing you of energy dollars spent.
As the baffles are to stop insulation from clogging the intake opening/help direct air stream along roof sheathing and stop wind-washing of the floor insulation; you could substitute rolled fiberglass in a plastic bag, thin plywood strips of acceptable height (though this may pickup incoming moisture and mildew) or rigid foamboard (optimum for reduced clearance over sloped areas yet meet code minimum energy rating- not in your case with raised heels). If the heel-height is enough with only blown-in, just add some housewrap stapled under the top chord framing and forget the baffles. You really want/need the vents in every rafter/truss bay to wash all the slope areas against moisture.
Gary
PS. may want to cover the blown (if FG) with 2-3" cellulose or housewrap to prevent convective loops
Old 10-07-2015, 08:14 AM   #7
Rewards Points: 229
Awesome, thanks. I did find out a larger concern is keeping critters out of the soffit area. I guess it is common for them to get into the soffit and thru a baffle and nest in the attic. I'll adjust venting nfa with the amount of vented soffit.
Old 10-07-2015, 09:06 AM   #8
Rewards Points: 244
I see a problem with some of the venting theory. Cold air doesn't push warm air up but only replaces that warm air that exits by convection so ridge to soffit ratio doesn't matter.
Old 10-07-2015, 12:55 PM   #9
Registered User
Rewards Points: 526
Six years ago I thought the same thing... researching the subject further I found: #2 and #7 here; http://learn-science.20m.com/tmyths.htm#myth2
Read the concluding Q&A here; http://usatoday30.usatoday.com/tech/...derquest_x.htm
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Windows on Wash (10-07-2015)
Old 10-07-2015, 07:58 PM   #10
Rewards Points: 229
Per the home made housewrap baffle....would that not deteriorate over the years and cause a future headache over a plastic baffle? I like the idea of saving on funds but wonder if it may bite me in the future.
Old 10-07-2015, 11:21 PM   #11
Registered User
Rewards Points: 526
No idea what would shorten its life in your attic... not moisture, air, staples rusting (use galvanized), temperature- within limits... why would it fail? Conduction energy loss would be slightly more than a thin foamboard one... you only need them at the bottom to prevent wind-washing- now I'm repeating...; http://www.philwrites.com/AW_Manual_12_1_all_LR.pdf
Someone else also wrote about it a few years after I used it on this forum; http://www.finehomebuilding.com/item...lation-baffles
Gary
Old 10-19-2015, 07:05 AM   #12
Rewards Points: 6
Thanks for advice. It seemed to be dead end with me.
BrookLarson is offline   Reply With Quote
Attic insulation suggestions? iwfur25 Insulation 1 07-09-2012 11:50 AM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
New Roof marknok Roofing/Siding 4 08-06-2011 11:41 AM
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 10:50 AM
Trying to Vent Attic Properly stephensandlin HVAC 4 08-03-2009 11:15 AM
