Attic Insulation: Lay New Over Old Or Remove? - Insulation - DIY Chatroom Home Improvement Forum
Old 11-02-2014, 07:44 AM   #1
Rewards Points: 20
Attic Insulation: Lay new over old or remove?
I am slowly converting a two apartment cinder block beach cottage into a garage and now want to insulate the attic area. Its a typical two car garage and about sixty-year old.
The beams are 2x6's and about half has the pink insulation that I estimate is 3" and about 1/2 of it has flattened over the probably sixty year old building. It is not secured nor stapled to the joists. Joists widths are 22.5 inches.
I'll use the 8' x 23" x 6" batts. Should I remove the old insulation or just lay the new stuf over the old...where it exists?
hunt4cleanair is offline   Reply With Quote
Old 11-02-2014, 09:34 AM   #2
Rewards Points: 144
1st. make sure the area is "air sealed". all the insulation in the world does no good, if there are holes in the ceiling.
then use blown in cellulose. it gives an over all better coverage. HOME DEPOT gives the machine rental free if you buy enough. you need a helper. otherwise it goes in real fast and real easy !
Fix'n it is online now   Reply With Quote
Old 11-02-2014, 10:46 AM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,940
If it's just a garage, are you really concerned with the temp? Drywall alone does wonders for temp control.
If it is just a garage, I wouldn't do anything.
Old 11-02-2014, 12:01 PM   #4
Rewards Points: 20
It's a garage in the South along the coast where humidity infiltrates and causes mold on rubber and vinyl among a couple of classic Corvettes.
To manage heat and humidity, and add the element of climate control for garage work in the winter. I run a split duct heat pump with A/C in the summer and heat in the winter. Thus, the incentive to introduce some element of climate control
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-19-2011 11:31 PM
AC Flex Duct - Suspend above attic insulation or lay it on top? fritzycat1 HVAC 13 08-17-2011 10:19 PM
i would like to remove old insulation from attic and start over with blue jean insulation in attic. My brother thinks this is a waste of time. I plan on pulling up old original boards and putting down new blue jean insulation followed by new plywoo waverunner Flooring 2 02-27-2011 07:07 PM
Damp Insulation in Attic wiz561 Building & Construction 6 12-23-2010 11:16 PM
