Attic Insulation Improvement - Insulation - DIY Chatroom Home Improvement Forum
Old 12-01-2014, 07:50 PM   #1
Rewards Points: 2
attic insulation improvement
I have an upstairs bedroom that is adjacent to an attic area. The attic floors have fiber glass insulation with some gaps. the wall between attic and bedroom has insulation that looks thinner and brown sawdust looking filler in it. (bungalow style house built in '48)
I'm thinking that old insulation may not be efficient enough and causing drafts.
Should I remove old insulation or can I put newer fiberglass bats over existing insulation?
thanks for any help
kat01 is offline   Reply With Quote
Old 12-01-2014, 08:43 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 766
If you are referring to the insulation on the floor, it will be easiest to just loose fill blow new insulation over top.
If you were referring to the insulation on the vertical walls, you will be best served to remove that insulation, seal the gaps, install new batt insulation, and cover with a rigid foam.
I would also air seal all of the penetrations and air leaks on the attic floor prior to blowing in more insulation.
Attic Insulation & Sealing planning fstr Insulation 7 11-19-2012 10:54 AM
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 01:54 PM
Attic Insulation tim1218 Insulation 4 09-07-2011 10:18 AM
Adding attic insulation pomelo Building & Construction 3 10-22-2009 05:19 PM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 02:13 AM
