Attic Insulation Help - Insulation - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By carpdad
Old 12-24-2018, 11:33 AM   #1
Rewards Points: 60
Attic insulation help
I live in Northern NM with cold winters, and range 5 per map.
My house was built in 68 the put rock wool batts in r 5 or 10 vapor barrier facing up. Then at some point some laid r15 craft face batts up cross wise over .
So I am now trying to decide what to do.
1 remove rock wool lay down the r 15 against the dry wall, roll R 30 on top of that.
Any ideas?
toastyjosh is offline   Reply With Quote
Old 12-24-2018, 12:07 PM   #2
Rewards Points: 1,998
Re: Attic insulation help
Should be no gap between. I'd use the batt that can fill or overflow the ceiling joists, paper down on the drywall. Then the rest on top but without the vapor barrier or cut slits in the paper without cutting too deep into the batt. Ideally, batts should lose the moisture into the attic then vent it out.
Dave Sal likes this.
carpdad is offline   Reply With Quote
Can/should I add insulation underneath stationary stairs to my attic? Bitruder Insulation 3 12-28-2012 11:04 PM
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 01:54 PM
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 08:49 AM
Blown in insulation for un-insulated attic Cubey Insulation 10 10-19-2011 07:08 PM
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 02:10 PM
