Attic Area - Insulation - DIY Chatroom Home Improvement Forum
Old 06-19-2014, 07:30 AM   #1
Rewards Points: 93
Attic Area
I'm adding Smart-Vents to an area over a bedroom. I opened up the small gable vent and this is what I found for insulation. Looks like blown in but there is a ton of space between the insulation and the rafters.
Is this typical and adequate for the space?
johnpma is offline   Reply With Quote
Old 06-19-2014, 12:44 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,022
What do you mean by "Smart - Vents"? Do you mean something like DCI's product?
Old 06-19-2014, 02:04 PM   #3
Rewards Points: 93
Yes, correct. Adding those on roof above the soffit, I cut in a ridge vent, and I need to vent the roof where the valley of the two pitches meet so I have air flow from the lowest part of the roof up along the shown rafters and then into the attic area and out the newly installed ridge vent
Old 06-19-2014, 04:14 PM   #4
Rewards Points: 1,916
In your area there was suppose to be at least R50 which would be about 12" of insulation.
The attic also should have been air sealed before insulating.
Air sealing is no more the using expanding foam around any place anything was run though the top plates or ceilings into the attic.
Wiring, plumbing, lighting or ceiling fans.
Old 06-20-2014, 12:40 AM   #5
Following, thanks.
Jerven is offline   Reply With Quote
Old 06-20-2014, 06:07 AM   #6
They are so tight to the sheathing that unless the insulation is packed in there, you should be fine with the addition of those vents. They do work.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Huge house with tons of 'dead' area in attic tibberous Pest Control 7 11-24-2011 09:01 AM
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 08:49 AM
Raccoons in the attic electricpete Pest Control 17 05-12-2011 04:02 AM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 12:42 PM
