Is This Asbestos? Should I Be Concerned? - Insulation - DIY Chatroom Home Improvement Forum
Old 07-02-2015, 11:00 PM   #1
Rewards Points: 424
Is this asbestos? Should I be concerned?
Here is the space above my window roof area. It is filled this type of insulation.
Is it asbestos?
I am not sure of the age of the house but it is atleast 40 years old I would guess.
(let me know if you need more pictures)
ghary is offline   Reply With Quote
Old 07-03-2015, 05:36 AM   #2
Rewards Points: 1,900
Hard to tell for sure from those pictures, one looks like rock wool, another looks like blown in fiberglass.
Only way to know for sure is to have it tested.
craig11152 (07-06-2015)
Old 07-03-2015, 08:02 AM   #3
Rewards Points: 424
Here is another pic:
Would taking some of the stuff out and taking a pic on a table help?
Old 07-03-2015, 08:08 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 928
Doesn't appear to be but if you are concerned, get it tested.
Old 07-03-2015, 09:23 AM   #5
Civil Engineer
Rewards Points: 5,246
"Is it asbestos" has been asked dozens of times on this forum in the last five years. The answer is always the same. It is IMPOSSIBLE to tell visually whether any product has asbestos in it. The only way to make a determination is to take a sample to licensed laboratory and have it tested,m generally used a special microscope. Over the last 100 years, thousands of different products have used asbestos, including numerous types of building material and insulation. If you want to know, get it tested.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
Gymschu (07-06-2015)
Old 07-03-2015, 11:16 AM   #6
Rewards Points: 50
Test each material, that is indeed the only way to know. I sent two samples of materials from my house into Western Analytical and for $50 I had an email the same night they received them with test results along with percentage of asbestos in the one positive sample.
troyks is offline   Reply With Quote
Old 07-03-2015, 11:19 AM   #7
Rewards Points: 424
I was thinking of visiting the doctor and asking for a chest x-ray.
Old 07-03-2015, 01:29 PM   #8
Rewards Points: 928
Have you been sleeping in the attic? If not, no reason to do so as a result of what is up there.
Old 07-03-2015, 02:08 PM   #9
Rewards Points: 424
The hole is right next to my bed, I had it sealed up like this for 3 months:
Old 07-03-2015, 02:30 PM   #10
Rewards Points: 424
I grabbed some out, here is a pic. The insulation is about the size of a CD.
(The full size can be opened up if you click on the pic.)
Old 07-03-2015, 04:08 PM   #11
Rewards Points: 928
That appears to be blown in fiberglass and you aren't getting any real exposure through that cardboard and tape. You are fine. Trust me.
The folks that have suffered from asbestos got exposed to a whole bunch of it and the folks that have the most systemic problems from their exposure were smokers.
Do you drink or smoke. If so, you are at far greater risk from that.
Old 07-05-2015, 09:18 AM   #12
Rewards Points: 424
That is good to hear.
I am going to have to repair that hole before winter comes, I was thinking of wearing a mask and cleaning it out and then replacing the insulation with the pink stuff that I seen at Home Depot. How does that sound?
Old 07-05-2015, 10:33 AM   #13
Rewards Points: 928
Sounds fine. Be sure to have proper PPE (Personal Protective Equipment) on and you should be good.
Old 07-05-2015, 12:35 PM   #14
Opps, didnt mean to post, dont know how to get rid of this
MechAdvantage is offline   Reply With Quote
Old 07-05-2015, 12:59 PM   #15
Rewards Points: 928
Never. It's here forever and will signify your misdeed for eternity.
Just kidding. I am sure the moderators will delete.
Happy Sunday.
Asbestos resources Pt 1 RWolff How To Guides 11 08-01-2013 08:26 PM
removing old laminate flooring in kitchen concerned about asbestos chrw45484 Flooring 11 08-14-2011 12:05 AM
Botched Asbestos Removal Several Years Ago...Remediation? vs1988 General DIY Discussions 10 08-16-2010 11:28 PM
asbestos & paint--let's talk. jaes Painting 4 08-10-2008 10:49 AM
