Asbestos Insulation? - Insulation - DIY Chatroom Home Improvement Forum
Old 02-02-2015, 05:11 PM   #1
Rewards Points: 8
Asbestos insulation?
Hi everyone,
I wanted to get some help to identify this water pipe insulation
Thanks in advance
corolla123 is offline   Reply With Quote
Old 02-02-2015, 05:48 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 944
Looks like TSI.
That stuff is extremely friable and very dangerous. Proceed with caution even when working around it. Unless you absolutely know what you were doing, this is a job for a professional abatement company.
Old 02-09-2015, 09:57 AM   #3
Civil Engineer
Rewards Points: 5,246
It is impossible to determine if a particular material contains asbestos without having it laboratory tested. Locate a laboratory near you that has asbestos testing capability, go visit, and they will give you a sampling kit with instructions. Then they can test your sample and tell you if there is asbestos in the material. This cannot be done by visual inspection, and certainly cannot be done on an internet chat forum such as this one.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
Windows on Wash (02-09-2015)
Old 02-09-2015, 11:44 AM   #4
Rewards Points: 129
Agreed. But it is probable in this case. No reason to panic but do have it tested and proceed as if it does contain asbestos till you know otherwise.
jimn01 is offline   Reply With Quote
Old 02-09-2015, 01:29 PM   #5
Rewards Points: 8
Thanks everyone for your input, if it is not disturbed / I dont touch it, it's safe right?
Old 02-09-2015, 02:56 PM   #6
Civil Engineer
Asbestos is a problem when it is friable, meaning it is breaking into small pieces that can get airborne and be inhaled. You are the only person who can see the actual insulation condition, so you are the only one who can judge if it is friable in its current condition. If it is flaking off and getting airborne, and if the insulation contains asbestos, then I would say it is not safe.
Old 02-09-2015, 04:33 PM   #7
Master General ReEngineer
Bondo's Avatar
Rewards Points: 6
Ayuh,.... There's no reason to walk out the door, 'n stay at a motel, til it's mitigated,...
No,....
But ya should take a small sample, 'n send it out for testin', 'n explore yer options,...
Yes,...
What is the R-value of Asbestos Insulation steppinthrax Insulation 4 01-10-2015 08:37 PM
Was asbestos used as attic floor insulation in the UK grant452 Insulation 6 05-20-2014 05:16 AM
Identifying asbestos products mgp roofing Safety 14 04-04-2014 04:46 AM
Ever encounter asbestos in foam board insulation? lilbilly Insulation 7 09-25-2012 02:45 PM
Assuming Asbestos Tile mcconnre Flooring 35 11-14-2008 01:56 PM
