Was Asbestos A Good Insulator? - Insulation - DIY Chatroom Home Improvement Forum
Old 02-24-2015, 04:47 PM   #1
Rewards Points: 42
Was Asbestos a good insulator?
Aside from the dangers of making it airborne, is asbestos a good insulator and what is the R value?
I have a ceiling joist between the first and second floor that are packed 8" deep with asbestos.
So much that it is very sound deadened.
I recently insulated my cap cod upper bedroom and completely sealed the knee walls from the none controlled dead space behind the knee wall.
I'm concerned heat is being lost from the floor underneath escaping out into the none controlled space behind the knee wall.
Like I said though, the floor joist are packed tight with 8" of compressed asbestos.
Leave it alone or what should I do?
borzym60 is offline   Reply With Quote
Old 02-25-2015, 07:36 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 878
It was pretty good at the time given the fact that it is impervious to fire.
If you don't need to disturb it, I would leave it. It works pretty well and depending on the fiber and type, is consistent with currently loose fill insulation R-Values.
Identifying asbestos products mgp roofing Safety 14 04-04-2014 04:46 AM
mold and asbestos pulper Flooring 2 09-02-2012 10:40 AM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 01:46 PM
Painting asbestos siding jstickel Painting 10 11-23-2008 11:34 AM
Assuming Asbestos Tile mcconnre Flooring 35 11-14-2008 01:56 PM
