Airsealing Inside Electrical Box - Insulation - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Nealtw
  • 1 Post By CodeMatters
Old 12-12-2019, 08:11 AM   #1
GBunny
Rewards Points: 95
Airsealing inside electrical box
I did read the post below regarding sealing outside an electrical box.
My electrical box is built onto a piece of wood attached to the bare outside wall. Unfortunately, the wood does not cover the entire exposed wall inside the box.
The wires lay right against the wall. The floor joists are exposed above it.
What is the best way to insulate this box?
GBunny is offline   Reply With Quote
Old 12-12-2019, 08:19 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 7,798
Re: Airsealing inside electrical box
Can you post up a picture?
Old 12-12-2019, 02:08 PM   #3
GBunny
Rewards Points: 95
Here are the pics of the electrical box that needs to be insultated
Airsealing inside electrical box-20191212_085046.jpg   Airsealing inside electrical box-20191212_085137.jpg
Old 12-12-2019, 02:25 PM   #4
retired framer
Rewards Points: 4,494
I would frame it out to match the lower wall leaving the space open for a face frame and door and insulate the new walls and glue a 2" foam to the back of the door.
Windows on Wash likes this.
Do not use flat bottom gables with scissor trusses.
Old 12-12-2019, 09:33 PM   #5
Usually Confused
lenaitch's Avatar
Rewards Points: 692
I must be missing something. Are we talking about the white duplex receptacle next to the breaker panel? If so, why does it need to be insulated?
Also, is that mould on the foundation wall (the 'black stuff')?
Edit: I decided I think you mean the breaker box itself, which appears to only partially mounted onto plywood. Unless you are really comfortable with matters electric, I'm not sure this is a DIY job as the panel may have to be pulled away from the wall. Also, I believe breaker panels now have to be mounted on a non-combustible barrier such as drywall, but I'm not sure if this is Ontario Code or, if it is, whether any modification would continue the grandfathering.
_________________________________________
Sic Itur ad Astra
lenaitch is offline   Reply With Quote
Old 12-12-2019, 09:50 PM   #6
Commercial. Const. ret.
surferdude2's Avatar
Rewards Points: 2,114
I'd pull it out and remount it as a surface mount. As is, that box may sweat in the winter and be a big problem. It would where I live! If you move it out, you will need to box around it to hide and protect the cables coming in, to please the inspector. I don't see how it got approved as is, doors or no doors.
SD2
surferdude2 is online now   Reply With Quote
Old 12-12-2019, 10:05 PM   #7
CodeMatters's Avatar
Rewards Points: 7,352
Just for your own info @lenaitch , that was in the OESC (Ont code)
at one point but is no longer. Wouldn't swear to it, but think it was
added to the 2002 code cycle then removed in the next cycle which
was 2006. What I'm quite certain of is that it was removed by 2006.
Haven't heard of any other jurisdiction with this requirement, but
couldn't say with certainty.
lenaitch likes this.
CodeMatters is online now   Reply With Quote
The Following User Says Thank You to CodeMatters For This Useful Post:
lenaitch (12-12-2019)
