Airkrete - Insulation - DIY Chatroom Home Improvement Forum
Old 01-17-2015, 09:43 AM   #1
Lord of Slums
Rewards Points: 1,974
Airkrete
https://www.facebook.com/AirKrete
Anyone have any experience with this stuff?
mj12 is offline   Reply With Quote
Old 01-17-2015, 10:26 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 856
Not personally but I have discussed it in detail with a gentleman that uses quite a bit of it when we were looking at it. Interesting stuff, but requires a pretty significant set up and the right applications.
Old 01-17-2015, 05:40 PM   #3
Registered User
Rewards Points: 526
No exp. with it, lot of info on web; comments; http://www2.buildinggreen.com/articl...on-alternative
no bonding to wood frame house that expands/contracts through seasons, as it shrinks; http://www2.buildinggreen.com/articl...thout-plastics
don't fill a brick air space with it; http://www.nachi.org/forum/f18/air-k...riences-36848/
R-4 per in, not R-6, requires a vapor barrier per location; http://inspectapedia.com/Energy/Conc...Insulation.htm
More; https://www.google.com/search?q=air+...utf-8&oe=utf-8
Gary
AirKrete Insulation 1910NE Building & Construction 1 02-24-2011 12:28 PM
