Air Sealing/insulating Flue In Attic? - Insulation - DIY Chatroom Home Improvement Forum
Old 06-17-2015, 01:25 PM   #1
Rewards Points: 83
air sealing/insulating flue in attic?
Getting ready to put more insulation in my attic and noticed the 12in x 12in chase for the water heater exhaust flue that extends into the attic is wide open. The furnace is high efficiency and so only the water heater uses this exhaust flue.
I was reading online about code for keeping insulation so many inches away from the exhaust flue but it sounded like it was for furnaces that exhaust into it (mine just has the water heater). The flue is not warm to the touch or anything ( and is currently wrapped in fiberglass and has been for 3 decades).
Any problems with air sealing the chase with foam board and putting insulation on top around pipe or is this still a code no-no?
AllGoNoShow is offline   Reply With Quote
Old 06-19-2015, 01:44 PM   #2
BarryP's Avatar
Rewards Points: 8
If the flue is not introducing heat into the attic, then don't bother with it.
BarryP is offline   Reply With Quote
Old 06-20-2015, 12:15 AM   #3
Registered User
Rewards Points: 526
I'd use sheet metal/fire caulking at the flue sides, pp. 19/60; http://apps1.eere.energy.gov/buildin...ing_report.pdf
Check with local AHJ or Fire Marshall if insulating the chimney... seems it would temper the cold winter attic air from the warm exhaust gases which carry water that would condense on the pipe/flue sides quicker...
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Dave Sal (07-07-2015)
Old 06-23-2015, 12:10 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 928
Sheet metal and itumescent caulking where it meets the chimney.
Attic insulation simagic Insulation 1 05-07-2014 12:06 AM
Insulation in the attic when the furnace is up there Jimmybrp Insulation 2 12-11-2011 02:26 PM
Attic - Replacing electrical - Positioning, how many boxes, checking understandings darlingm Electrical 12 12-04-2011 11:17 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 08:10 PM
