Air Sealing At Gable Ends, With Brick Cladding? - Insulation - DIY Chatroom Home Improvement Forum
Old 09-29-2018, 05:44 PM   #1
Rewards Points: 337
Air sealing at gable ends, with brick cladding?
My house was built in 1951, brick cladding on the main floor and three large wooden gables above. I'm getting ready to air seal the attic, and I notice at all the gable ends of the attic, where the rafters end, there's a drop of about 18 inches, to what looks like the top course of the exterior bricks. There appears to be a space of about 1/2 inch between the inner side of the bricks and what looks like the outer edge of the wall sheathing.
Now, this space needs to stay open to the attic, correct, so water vapor from the brick can escape?
I'm planning to have cellulose blown in to the attic to a depth of 13 inches, but I need to make sure no cellulose goes down into those spaces, right? So I need to put some type of barrier that blocks the cellulose, but lets air pass?
dave11 is offline   Reply With Quote
Old 09-29-2018, 05:58 PM   #2
retired framer
Rewards Points: 580
Re: Air sealing at gable ends, with brick cladding?
I think you could block the top the space is drain plane and you should have weep holes at the bottom of the brick. You want a fire stop from the wall to the attic and that would be a perfect chimney for the wall fire.
sealing brick house from slugs Startingover Carpentry 4 01-17-2015 10:39 AM
Need advice on brick cleaning / sealing & pavement projects mystiky Concrete, Stone & Masonry 3 08-06-2014 02:30 PM
Turn Key Roofing Installation - Single Story, Gable ends, No Valleys darrelllosey Roofing/Siding 8 10-05-2012 06:44 AM
Sealing Brick Pavers sflamedic Painting 9 04-11-2011 09:17 PM
TV Mount onto Brick Fireplace- Brick Integrity? andrew.volkart Building & Construction 4 03-01-2011 07:21 PM
