Air Sealing Electrical Box Knockouts - Spray Foam Or Something Else? - Insulation - DIY Chatroom Home Improvement Forum
Old 12-28-2019, 10:44 AM   #1
Rewards Points: 354
Air sealing electrical box knockouts - spray foam or something else?
In a room I'm renovating, I'm getting ready to install insulation batts. But before I do, I need to air seal the electrical box knockouts (where the wires enter and exit the outlet boxes).
I was going to use canned spray foam for this. Any tips on minimizing how much foam enters the box? Maybe stuff a rag into the box and press it up against the knockouts while I foam the outside of the knockouts?
Or is there another product that is better suited to this task? Perhaps duct seal putty, like this: https://www.homedepot.com/p/Gardner-...-110/100212441
jbrah is offline   Reply With Quote
Old 12-28-2019, 11:54 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 904
Re: Air sealing electrical box knockouts - spray foam or something else?
Putty pads are easiest if the walls are open.
Old 12-28-2019, 12:09 PM   #3
retired framer
Rewards Points: 600
Or caulk them on the outside.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
