Air Gap Between Chimney And House Framing - Insulation - DIY Chatroom Home Improvement Forum
Old 09-30-2017, 09:40 PM   #1
Rewards Points: 114
Air gap between chimney and house framing
I have a chimney that is used by 2 working fireplaces, and the furnace. its in the middle of my house.
In the attic, there is a 3" air gap the apears to go all the way down to stone face on the front hte fire place in the living room.
Should I fill this gap with insulation or leave it be?
Getting a picture will be quite difficult as I just sprayed 18" of loose cellulose up there today.
That Guy is online now   Reply With Quote
Old 09-30-2017, 10:54 PM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: Air gap between chimney and house framing
Describe the configuration of the furnace and the surrounding materials, please.
Is the Chimney pipe insulated? Are the walls framed or brick?
Three flues or a single one?
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 10-01-2017, 10:20 AM   #3
Rewards Points: 114
In the attic, it appears the entire chimney is made out of cinder block, then in the basement and living room has stone faced. In the garage, opposit of the living room, its brick. and outside on the room its brick.
3 flues, all 3 are clay.
In the attic, its framed around the chimney with wood framing, creating that gap.
This past summer, I fillied in on the back of the chimney as far down as I could reach with expanding foam as you could see the light from the garage poking through.
Also, while in the attic, looking up along the chimney you can see daylight in spots, but there is zero indication of any water coming in.
Going back to my college days, i know the chimney is its own free standing structure, seprate from the house.
But should I fill that gap the gap created by the framing around the chimney in the attic, or just not worry about it?
I am curious if this is a potential area for loss of heat in the winter.
Old 10-01-2017, 03:03 PM   #4
jlhaslip's Avatar
Rewards Points: 708
Unless that foam is fire rated (and there is such a foam) it needs to remain separate from the flue by a certain distance, which is dictated by your local/state codes.
I would find out what that spacing requirement is for your area and adhere to it.
Maybe block the daylight and leaks using metal?
Old 10-02-2017, 11:30 AM   #5
Rewards Points: 477
If the chimney is double walled (flue inside the block structure) then the framing should be fire blocked tight to the CMU using fire rated materials... usually at the top plate/ceiling, more often if the distance between plates or between floors exceeds 10'.
XSleeper is offline   Reply With Quote
How to install chimney liner Rockford How To Guides 3 07-16-2012 04:15 PM
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 10:00 AM
Chimney separation from house. - help - image attached mburgess44 Building & Construction 6 09-01-2011 09:41 AM
wet chimney inside the house... sobro Roofing/Siding 3 04-14-2011 04:03 PM
Vinyl sided chimney on side of house - rotting OSB rfleege Roofing/Siding 55 11-23-2010 08:23 AM
