After Foam Board Insulation Completed Question. - Insulation - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 07-07-2017, 08:15 AM   #1
Rewards Points: 76
After foam board insulation completed question.
Hello all I'm almost done installing 1 1/2 thick foam board all around my bsmt walls. Before I did it the bsmt was so humid and moldy smelling. I had efflorrance fit no actually seeible water penetration. So not that it's almost done I feel the bsmt is now hot and Dense no humid feeling no musty smell I was wondering if I should install a air exchanger on one side of my bsmt rim joists to circulate air around? I have windows in the bsmt should I just leave them open constantly. Any information would be great.
Sent from my SM-J327P using Tapatalk
charles3526 is offline   Reply With Quote
Old 07-07-2017, 09:34 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 928
Re: After foam board insulation completed question.
There should be conditioned air circulation in the basement.
Are the rim joists sealed and insulated.
Old 07-07-2017, 09:41 AM   #3
Rewards Points: 76
Yes they are all seald up.
Old 07-07-2017, 09:45 AM   #4
Rewards Points: 928
Any ductwork in the basement? You just need some air circulation and conditioning at this point.
If the whole home (i.e. in total) is super tight, you may need to look at an HRV or ERV.
Old 07-07-2017, 09:47 AM   #5
Rewards Points: 76
No ductwork just a oil tank washer dryer boiler and soon to be play area.
Old 07-07-2017, 09:47 AM   #6
Rewards Points: 76
I was looking into a air exchanger unit
Old 07-07-2017, 11:13 AM   #7
Rewards Points: 214
Once the basement is sealed and insulated it becomes part of the upstairs conditioned space and can benefit from sharing that air. Opening a window or venting outside air into the basement may introduce a lot of moisture from the humid air.
An HRV can exchange inside with outside air when needed but you haven't determined that need as yet. A blower door test is one method. But when not needed it says the house is already exchanging enough air.
Are you running ac upstairs and where are you located?
Bud
Bud9051 is online now   Reply With Quote
Old 07-07-2017, 11:27 AM   #8
Rewards Points: 76
They did the door test last year for my energy audit. I'm Located in new York city. The a.c. is on all day on my upstairs main floor the bsmt is below level
Old 07-07-2017, 11:28 AM   #9
retired framer
Rewards Points: 768
Do you have air supply to replace what you and the dryer and the boiler are using.
Old 07-07-2017, 11:44 AM   #10
Rewards Points: 76
No air supply coming in unless windows are open. Boiler uses are inside the bsmt
Old 07-07-2017, 12:46 PM   #11
retired framer
Rewards Points: 768
We do rooms under the garage out here that end up being a concrete box with a door from the basement. They have a fresh vent and a bathroom exhaust that runs when the light is on. That usually gets closed off when the conditioning is added.
But the boiler or furnace needs air for the fire anyway.
Old 07-07-2017, 01:09 PM   #12
Rewards Points: 76
Yeah so the air intake is just taking it from the air in the basement
Old 07-07-2017, 01:20 PM   #13
Rewards Points: 76
So maybe I should get two exchangers if I'm gonna close off part of the basement and install each one on the side of the basement walls by the boiler and then in the other room?
Old 07-07-2017, 02:11 PM   #14
Rewards Points: 76
This is what I was looking at buying
Old 07-07-2017, 02:58 PM   #15
Rewards Points: 214
Do you have the blower door numbers, CFM50 or ACH. (cubic feet per minute at 50 Pascals) or (Air Changes Per Hour at 50 or natural)?
Those numbers will tell you whether fresh air is needed or not.
Example, a house at the borderline of needing additional fresh air will be exchanging all of the inside air with outside air every 3 hours. Even a reasonably tight home will be exchanging all of its air every 4 hours, so adding more is just a waste of energy. The unit you pictured just blows air with no attempt to recover the energy for what is being blown out.
Combustion air for your boiler has specific requirements in terms of vent size and location and the dual fan you pictured would not meet those requirements.
Do you get condensation on your windows in the winter. In a cold climate a tight house will have high indoor humidity and window condensation becomes an indicator. If not, the house does not need to exchange more air. Those blower door numbers will confirm.
The basement air does need to mix with the conditioned air from upstairs which is easy when you have a forced hot air system, but needs another solution with baseboard hot water heat.
Bud
Foam Board Insulation issues zpotas Insulation 6 07-13-2017 01:32 AM
Garage ceiling foam insulation question richlux Insulation 6 10-16-2015 04:26 PM
Foam Board Insulation on rafter in attic to box in AC system sinrich Insulation 12 04-09-2014 05:52 AM
question on foam board installation ROB62 Insulation 3 05-09-2012 11:28 PM
Question regarding Housewrap and Foam board insulation psychomti Building & Construction 16 10-27-2010 08:50 PM
